Toymods » Tech & Conversions » opening an AFM from a 20v Bad idea??
Switch to threaded view of this topic Create a new topic
LAA.80E
The realist ghetto area P...
April 2005
opening an AFM from a 20v Bad idea?? Wed, 19 October 2005 06:48 Go to next message
hay ! just wanting to know if theres anything i could do to the afm in a 20v to increase power of any sort iv alrady opend the thing up and just wanna know if i should tamper wid it!
thanks guys
ke382TG
Re: opening an AFM from a 20v Bad idea?? Wed, 19 October 2005 07:06 Go to previous messageGo to next message
Tampering often leads to bad things mmmkay.
You "adjust" things when you know what you are doing, if you tamper with things you will then have to take it to someone who knows how to "adjust" things that have been tampered with.
This will lead to the handing over of $$$ and the end result will be that you are right back to the point at which you are now.
Choose your next move wisely.
LAA.80E
April 2005
Re: opening an AFM from a 20v Bad idea?? Wed, 19 October 2005 07:10 Go to previous messageGo to next message
well thats the truth but i like to learn from my mistakes! learn new things at no matter what cost cause ill end up having the knowledge for the future and im better off fuking up my car then anyone elses!
ke382TG
Re: opening an AFM from a 20v Bad idea?? Wed, 19 October 2005 07:17 Go to previous messageGo to next message
Let us know what the result is then.
Before and after measurements/times would be good. Seat-of-the-pants results don't count.
You do understand that there are only two things you can do to achieve an increase power by tampering with an airflow meter.
1. decreased inlet restriction (if it was at all a restriction) if restriction can be removed/opened up
2. improved A/F ratio if it was running too rich/lean (how do you plan to do this and then measure the outcome?)
EDIT: the tampering with AFM on 4AGZEs is well documented and the results have been varied and vague.
[Updated on: Wed, 19 October 2005 07:19]
love ke70
September 2005
Re: opening an AFM from a 20v Bad idea?? Wed, 19 October 2005 07:29 Go to previous messageGo to next message
if toyota could have got more power by adjusting the afm dont u think they would have.....i dont think it will make any difference
~andrew~
terra
July 2005
Re: opening an AFM from a 20v Bad idea?? Wed, 19 October 2005 07:42 Go to previous messageGo to next message
works great on a camry though Smile
i have the cog'ed wheel about 15 clicks clockwise... no more deadspot at around 4000rpm (after changing gears) and around 50km more per fuel tank Smile
LAA.80E
April 2005
Re: opening an AFM from a 20v Bad idea?? Wed, 19 October 2005 09:42 Go to previous messageGo to next message
well there you go atleast sum1 achieved sumfn out of it good!!!
iv heard of people tampering wid the afm on gze but how bout 20v??!!! thats why i wanna check it out,
terra
July 2005
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 05:42 Go to previous messageGo to next message
well if all ya gonna do is what i did (change the a/f ratio)
itll do whatever it does when you change a/f ratios.
so idle may get a bit buggered (i have put put crazy cam overlap sounding idle) but toyotas genrally run a bit too rich in the powerband/top end so youll get some form of improveent there.. as long as youre not lean enough to knock down low.
ed_ma61
Lost in the K hole
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 06:03 Go to previous messageGo to next message
LAA.80E wrote on Wed, 19 October 2005 19:42
heard of spelling????
as for tweaking the afm... doubt that you find any real measurable differences
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 06:12 Go to previous messageGo to next message
i don't understand the point of this thread???
the title sounds like a rhetorical question Confused
LAA.80E
April 2005
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 08:13 Go to previous messageGo to next message
yeah iv heard of spelling ! what is it that hard to read some little errors or sum internet slang? or are you just a little bit on the fuk wit side of things,
i ask a question then you get gronks talkn rubbish, all i asked was would i achieve anything if i tamper wid my afm.... majority said no not a good idea , so thank you to those who guide me.
ed_ma61
Lost in the K hole
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 08:24 Go to previous messageGo to next message
LAA.80E wrote on Thu, 20 October 2005 18:13
ok, so how about a coke, a smile, and nonw you shut the fuck up
LAA.80E
April 2005
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 08:31 Go to previous messageGo to next message
you can ask nicely , it aint gunna hurt
love ke70
September 2005
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 08:55 Go to previous messageGo to next message
ok, ill do it for you ed_ma61 hope u dont mind
laa.80e: you have been discouaged against modifiying your afm from your 20v, now can u please go and have a coke, flash us one of your million dollar smiles, and please shut the fuck up and let the thread die
how did i do guys?
~andrew~
LAA.80E
April 2005
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 09:12 Go to previous messageGo to next message
i will let the thread die , all you had to do is ask nicely and btw you sound like a puppet.
LAA.80E
April 2005
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 09:14 Go to previous messageGo to next message
better yet sumone delete this thread
cause i dont know how or i dont think i have the power too.
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 09:46 Go to previous messageGo to next message
LAA.80E wrote on Thu, 20 October 2005 19:14
considering you have been insulting the TECH SECTION MODERATOR.......
do i even need to finish the sentence?
should we be taking bets for how soon you get on probation?
decent spelling and refraining from using moron intahnet speak is not just a requirement. it is POLITE. it will get your questions ANSWERED.
ps
ahhahah hahha aaahhhh... do you always ask your doctor this when you go for a checkup? Laughing Laughing Laughing Laughing
[Updated on: Thu, 20 October 2005 09:48]
LAA.80E
April 2005
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 10:01 Go to previous messageGo to next message
jeeeeez, hay alls im trying to get to is ..... you asking me to spell correctly in a POLITE way cause the way i took it was a little harsh.
and you guys want to ban me, then its totaly upto you guys ,
get into my shoes and see were im coming from , you dont need to get all smart about anything mate or add any little p.s's quoting somthing perthetic.
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 16:12
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 18:24
((ok, so how about a coke, a smile, and nonw you shut the fuck up))
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 18:55
laa.80e: ((you have been discouaged against modifiying your afm from your 20v, now can u please go and have a coke, flash us one of your million dollar smiles, and please shut the fuck up and let the thread die))how did i do guys?~andrew~
i have a ke70 called delores
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 19:46
**(((do i even need to finish the sentence?
decent spelling and refraining from using moron intahnet speak is not just a requirement. it is POLITE. it will get your questions ANSWERED.)))** THATS WHAT I WAS DOING
ps
ahhahah hahha aaahhhh... do you always ask your doctor this when you go for a checkup? IS THERE TRUELY ANY NEED OF THIS???
DAMN FELLAS, I THOUGHT YOU WERE SUPPOSED TO BE POLITE AND HELPFULL?
[Updated on: Thu, 20 October 2005 10:05]
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 10:06 Go to previous messageGo to next message
oldcorollas wrote on Thu, 20 October 2005 16:12
i still don't understand the point of this thread.
opening an AFM from a 20V IS a bad idea.
thus, the title of this thread is a rhetorical question Wink
close her back up, stick it on the car and be a happy chappy Very Happy
LAA.80E
April 2005
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 10:09 Go to previous messageGo to next message
okay thanks mate
LAA.80E
April 2005
Re: opening an AFM from a 20v Bad idea?? Thu, 20 October 2005 10:10 Go to previous message
can sombody please tell me how i can close or delete this thread?
Previous Topic:NEED HELP - ENGINE OIL LEAK IN MY SOARER
Next Topic:MA61 strut tops... same as???
Current Time: Mon Nov 2 11:19:27 UTC 2026
Total time taken to generate the page: 0.012423992156982 seconds
