Toymods » Tech & Conversions » 3sgte vs 3sge block
MR. 2
Parramatta
3sgte vs 3sge block Wed, 19 October 2005 23:15 Go to next message
what is the differance between them if any???
both gen 2 3sgte and gen 2 3sge???
can it be used for a 3sgte??
JustenGT4
Re: 3sgte vs 3sge block Thu, 20 October 2005 02:25 Go to previous messageGo to next message
No oil squirters for the underside of the pistons in the n/a block. No oil feed for the turbo either.
They are definitely different castings from factory as well so sure there must be some structural differences but have never looked into it.
RAV-GT4
Toymods member
Rydalmere, NSW
Re: 3sgte vs 3sge block Thu, 20 October 2005 03:08 Go to previous messageGo to next message
What Justen said is probably the only noticeable block differences you'll find... the rest are in the sump, sump ass'y, head, etc. Both are still same bore x stroke (86mm x 86mm). Also some have 2-bolt mains, some have 4-bolt. I think from memory the ST205 block had 4-bolt mains and the ST185 block had the 2-bolt. Confused
MR. 2
Parramatta
Re: 3sgte vs 3sge block Thu, 20 October 2005 03:28 Go to previous messageGo to next message
bugger then that rules that out. just found a 3sge block well i should say they are everywhere but no 3sgte ones floating around.
thanks for that guys it helps.
spectral
Re: 3sgte vs 3sge block Fri, 21 October 2005 01:11 Go to previous messageGo to next message
Some early 3SGE have the mount holes bossed and tapped for RWD (north south) setup as well. 3SGTE don't from appearances, and will require a bit of creativity. From your avatar, this wouldn't be an issue for you of course, owning a SW20.
ST185 Bourkey
Robertson
October 2005
Re: 3sgte vs 3sge block Sun, 06 November 2005 10:19 Go to previous messageGo to next message
I have a 3S-GTE sitting in a paddock at home.
http://www.nfiracing.com/nfi/modules/Coppermine/albums/userpics/10029/102_1335640x483.jpg
havabeer
new castle
July 2005
Re: 3sgte vs 3sge block Sun, 06 November 2005 10:33 Go to previous message
if you ever need someone to take that 3s-gte off your hands for free bourkey, just give me a call Very Happy Wink
Previous Topic:putting a shim in a brake caliper..ok for track use?
Next Topic:Overheating problems
Current Time: Sat Oct 31 23:45:06 UTC 2026
Total time taken to generate the page: 0.053993940353394 seconds
