Toymods » Tech & Conversions » Celica axles and T18 housing
bluehachi
September 2005
Celica axles and T18 housing Wed, 19 October 2005 23:22 Go to next message
Will Celica (TA22, RA23 etc) axles fit into a T18 housing?
Henn
Rosanna, Melb
Re: Celica axles and T18 housing Wed, 19 October 2005 23:38 Go to previous messageGo to next message
TA22 has smaller wheel bearings. Unsure on RA23.
RA60 and RT132 both fit perfectly once you cut 10mm off the spline end. I assume RA40 work too, but haven't tried this myself.
Hen
bluehachi
September 2005
Re: Celica axles and T18 housing Wed, 19 October 2005 23:47 Go to previous messageGo to next message
cheers for clearing that up ben.
Re: Celica axles and T18 housing Wed, 19 October 2005 23:51 Go to previous messageGo to next message
ra23 and 28 axles are shorter than ra40/t18.
Jonny2TG
Tasmania
Re: Celica axles and T18 housing Thu, 20 October 2005 00:03 Go to previous messageGo to next message
RT132 axles are longer than RA23 ones. Rolling Eyes not sure if you needed to know that
4a-c
Sutherland Shire
Re: Celica axles and T18 housing Thu, 20 October 2005 11:26 Go to previous messageGo to next message
is there any reason its not possible to swap to the larger wheel bearing on a ta22 axle so it can be used in t18 housing???
Henn
Rosanna, Melb
Re: Celica axles and T18 housing Thu, 20 October 2005 11:51 Go to previous message
TA22 (and therefore I assume RA23 too) axles are about 20-30mm shorter than T18 axles as well as having the different bearing. Plus the cost of new bearings and labour of changing them means it wouldn't be worth it anyway.
Hen
Previous Topic:20v conversion & power steering
Next Topic:AW11 6 Speed gearbox - What will fit ?
Current Time: Sat Oct 17 18:45:31 UTC 2026
Total time taken to generate the page: 0.0045828819274902 seconds
