Toymods » Tech & Conversions » Mating 1G-Gte - AE 86 axle
dispatcher
Malaysia,Kuala Lumpur
Mating 1G-Gte - AE 86 axle Thu, 20 October 2005 13:08 Go to next message
I'm considering mating my 1g-gte with an AE 86 axle..but might have to change the ratios etc...am i wasting my time ?
Chassis is a GX60.
thanks all
CLG
Perth, Western Australia
Re: Mating 1G-Gte - AE 86 axle Thu, 20 October 2005 13:13 Go to previous messageGo to next message
Depends on how you want to drive it! If you want to beat up on it, go for a larger diff - F series would be a good starting point, if you simply want a daily driver with a bit more pep, the T series AE86 axle should be fine. Standard I think you'll find your CRessida will have an E series diff, so the T series diff will actually be reducing the size of the diff too - something to think about.
dispatcher
Re: Mating 1G-Gte - AE 86 axle Thu, 20 October 2005 13:28 Go to previous messageGo to next message
Hi CLG...thanks mate..here's the problem..my car's sitting with the mech for 5 months now..cause unable to get a suitable disc'd axle here in malaysia other then the Ae86..i know about the size reduction.It concerns me. The track is about the same size.
What F series axle could i use ?
CLG
Re: Mating 1G-Gte - AE 86 axle Thu, 20 October 2005 13:30 Go to previous messageGo to next message
MS112 Crown will be your easiest option.
Re: Mating 1G-Gte - AE 86 axle Thu, 20 October 2005 13:34 Go to previous messageGo to next message
Why not use a G from an old-school Hilux and be done with it? You'll be able to slot in a passable LSD, some sensible gears and it should be strong enough. Plus it'll be the right width.
CLG
Re: Mating 1G-Gte - AE 86 axle Thu, 20 October 2005 13:39 Go to previous messageGo to next message
If size and weight are not an issue, thats an option too, but you'll also need to do a disc brake conversion if you want discs!
dispatcher
In malaysia there were some MS112 crowns..hmm..suppose it be like looking for a needle in a haystack..the track width would be same almost i think...Mr.Shin would you know the chassis code for the Hilux you're reffering too ? Malaysia is Hilux-heaven.. Smile
Thanks Very Happy
dispatcher
Re: Mating 1G-Gte - AE 86 axle Thu, 20 October 2005 13:42 Go to previous message
CLG ...the AE 86 in hand is the LSD version with disc brakes.
Mr Shin..does the hilux you're reffering to come with disc brakes..
if not how do i convert it to disc ?
thanks.
Previous Topic:A340H manual shifting
Next Topic:Which tyre profile for 15s on rear 14s on front
Current Time: Sat Oct 17 21:17:16 UTC 2026
Total time taken to generate the page: 0.0048410892486572 seconds
