Toymods » Tech & Conversions » Error code 78
BootySlap
Error code 78 Fri, 21 October 2005 02:02 Go to next message
Upon entering diagnostics mode i get 7 flashes followed by 8 flashes. Error code 78 does not seem to be in the service manual.
On a bigport 4AGE. Anybody have any ideas ?
myne
October 2005
Re: Error code 78 Fri, 21 October 2005 02:32 Go to previous messageGo to next message
I'd be thinking ecu :/
I havent seen it mean anything either, unless you're confusing 2 codes as 1.
25
34
43
52
^ all = 7
26
35
53
^ all = 8
Look closer.
BootySlap
Re: Error code 78 Fri, 21 October 2005 02:37 Go to previous messageGo to next message
It definately seems like 7 flashes about every second and then a 4 second break followed by 8 flashes every second and repeat.
Unless I have two things wrong made up of 7 and one made up of 8 hmm I thought there was a 3second delay between each digit.
[Updated on: Fri, 21 October 2005 02:38]
myne
October 2005
Re: Error code 78 Fri, 21 October 2005 02:40 Go to previous messageGo to next message
4 second break you say? Sounds like the gap between 2 codes.
In which case, you may have 2 single digit codes.
http://www.off-road.com/toyota/tech/codes/
7=
--THROTTLE POSITION SENSOR SIGNAL
--OPEN OR SHORT IN TPS SIGNAL
--TPS SENSOR
--TPS SIGNAL/CIRCUIT
--ECU
8=
--INTAKE AIR TEMPERATURE SENSOR SIGNAL
--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
--INTAKE AIR TEMPERATURE CIRCUIT
--ECU
BootySlap
Re: Error code 78 Fri, 21 October 2005 02:47 Go to previous messageGo to next message
I think your right!
Ok for the 4AGE going from the service manual:
7 can be only
25 - Air-fuel ratio lean malfunction
43 - Starter Signal
52 - Knock sensor signal
8 can be only
26 - Air-fuel ratio rich malfunction
53 - Knock control signal in ECU
So it must be either 25 and 26 or 52 and 53. Didnt know mine had a knock sensor.
myne
October 2005
Re: Error code 78 Fri, 21 October 2005 03:50 Go to previous messageGo to next message
Unplug your oxygen sensor, go for 4 short drives(so that any codes are recorded)it need not be far, just drive, stop, turn off, start, repeat.
If I'm right, there will be no new codes.
If there are no new codes, odds are your oxy sensor is screwed, which could give random high/low mixture readings.
BootySlap
Re: Error code 78 Fri, 21 October 2005 04:07 Go to previous messageGo to next message
Im pretty sure I found out what it is.... a yellow plug near the TVIS manifold not connected, must be air temp.
Sensor was there on my old TVIS manifold, but no sensor there on the new one !! I dont really want to change the TVIS manifolds back over. Ive put in a 3K resistor there in the meantime and it drives much better. I might just take the old sensor out and connect it up and leave it floating around the engine bay.
Re: Error code 78 Fri, 21 October 2005 06:19 Go to previous messageGo to next message
78 is fuel pump ecu, so you definately don't have 78.
BootySlap
Re: Error code 78 Fri, 21 October 2005 06:46 Go to previous message
Connected the old air-temp sensor and just left it loose in the engine bay. Probably not the best place but works great for now!
Also timing was 0 BTDC, adjusted to 10 and feels much better.
Previous Topic:TA22 Intercooler
Next Topic:current flow when ign off??
Current Time: Fri Nov 20 23:49:55 UTC 2026
Total time taken to generate the page: 0.0060369968414307 seconds
