Toymods » Tech & Conversions » gearbox
frecstar
perth
October 2005
gearbox Fri, 21 October 2005 06:57 Go to next message
hi everyone. i would like to know what gearboxes can bolt on to a 2tgeu in a 72 corolla. i would also like to know if anyone knows of ways i could get a celica/supra 5spd in there. if anyone has any ideas whether it be bolt on or custom. any ideas on costs$$$.
tricky
July 2005
Re: gearbox Fri, 21 October 2005 07:12 Go to previous messageGo to next message
The box that came with the 2T was the T50. As far as sticking it in a rolla, it is a bit bigger than the stock box, and I think a bit longer, so a custom/modified cross member will be required. If you wanna stick a W5x box in there, you'll have a bit more work ahead of you. Someone else will have to confirm whether or not a W5x will fit in the trans tunnel, but the W55 came with 3TGTE's (among other things), so if you find one of these boxes, you'll have a suitable bell housing. Be warned though, they were never Australian delivered, hence they are rare. You'd also have to take into account the shifter on the W boxes is significantly further back than the original.
I'd presume you'd need a custom tailshaft, or a lot of luck with a tape measure also.
As far as cost is concerned, that depends on how muchwork you do yourself. If you can weld up any custom parts you need, it could cost bugger all for everything but the tail shaft.
Another interesting thing is the J160 (6 speed box in lexus IS200's) bolts up to 2TG's, but again, everything else would have to be cusso.
frecstar
perth
October 2005
Re: gearbox Fri, 21 October 2005 09:05 Go to previous messageGo to next message
thanks for that info very helpful. what would you reckon i should put in.
tricky
July 2005
Re: gearbox Fri, 21 October 2005 13:16 Go to previous message
Well, a T50 will handle the power of a worked NA 2TG and will take the least work to put in. So basically, I wouldn't go to the extra effort of the supra box unless you were planning forced induction.
Previous Topic:4A GZE Injector
Next Topic:Engine mounts for a 20v 4age
Current Time: Fri Nov 20 21:35:48 UTC 2026
Total time taken to generate the page: 0.0048689842224121 seconds
