Toymods » Tech & Conversions » 1ggze RUNS! idles!, need help, wont rev past 3,000rpm
rx793
Perth, Western Australia
1ggze RUNS! idles!, need help, wont rev past 3,000rpm Sat, 22 October 2005 17:04 Go to next message
Hey guys, it runs, and im happy! finally (for those of you who know the trouble ive had with this engine and wolf3d) but it runs, just wondering if anyone can diagnose why this is doing this.
For starters, its running ritch, as im going to let the tuner do that, but i just want to be able to get the full rev range to drive it to the tuner. When you open the throttle, it revs up to about 3 grand and no matter how much u open it afte that, just sits there at 3 grand. Popping and farting,
Now, if u jab the throttle u can get the full rev range, which leads me to think its air or fuel. Any ideas on the adjustments i should try?
Steve
Re: 1ggze RUNS! idles!, need help, wont rev past 3,000rpm Sat, 22 October 2005 17:56 Go to previous messageGo to next message
accidentally got a 3krpm rev limit programmed in?? or someting whacky with maps....
or something whacky with the ignition triggers or coil charge times?
i wouldn't be too afraid of playing around a little bit... just save the original settings so you can go back to a known set of parameters....
(oh, i hadn't been folowing your probs tho.. will look up)
HyDrA
Adelaide, SA
Re: 1ggze RUNS! idles!, need help, wont rev past 3,000rpm Sat, 22 October 2005 23:59 Go to previous messageGo to next message
I had similar problems a few times in the past. Once it appeared to be the Jaycar IEBC (suggesting fuelling) the other it was the ignitor not grounding that well.
Good luck with the problems mate Smile
Allan
Re: 1ggze RUNS! idles!, need help, wont rev past 3,000rpm Sun, 23 October 2005 10:22 Go to previous messageGo to next message
trailer it to the tuners
Re: 1ggze RUNS! idles!, need help, wont rev past 3,000rpm Sun, 23 October 2005 13:41 Go to previous message
Check your ignition triggers, make SURE you don't have any wires the wrong way around.
Previous Topic:4K Performance Problems... anyone had these before?
Next Topic:4A-GZE Gearbox Cooling?
Current Time: Fri Nov 20 19:23:38 UTC 2026
Total time taken to generate the page: 0.0045280456542969 seconds
