Toymods » General Car Talk » $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!!
sjsj
$25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Sun, 23 October 2005 07:06 Go to next message
Hi Everyone,
Brilliant news!! Found an inexpensive real-time logger to monitor any analog input signals on your car between -10V and +10V!! eg: O2 signal, AFM/MAF/MAP, TPS, fuel injectors, RPM, etc.
Examples of logged data (wideband O2 signal vs RPM) while accelerating is here:
http://cyberdave.org/carwb.html
http://cyberdave.org/CarTest.html
Cost/feature Details
1/ DI-194RS $24.95US
* 4 single-ended analog input channels ±10VFS.
* 10-bit measurement resolution
* RS-232 PC interface connection
* 240Hz maximum sample throughput
* details at http://www.dataq.com/products/startkit/di194rs.htm
2/ DI-148U $50US
* 8 single-ended analog input channels, ±10Volt full scale range.
* USB PC interface
* Up to 14,400 Hz sample throughput rate,
* Six digital TTL I/O lines for general purpose I/O.
* Details at http://www.dataq.com/products/startkit/di148.htm
Note: Appears to require expensive WinDAQ software to extract full capabilities. Consider alternative shareware/free software below:
Shareware/freeware software to drive a DataQ device ($25US)
http://www.ultimaserial.com/
http://groups.yahoo.com/group/ultimaserial_group/
Comments
I like the sounds of the USB model myself. Group buy anyone? Smile
Note: not affiliated with DataQ in anyway. Just sharing the good news.
sjj
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Sun, 23 October 2005 08:13 Go to previous messageGo to next message
doesn't look too bad,
240Hz is not really fast enoguh for engine stuff, but should be fine for temps etc...
the 10bit res is a bit lacking tho.. 20mV may not be enough for thermocouple accuracy.. but still, looks nice Smile
a little more expensive, but free software, and very good (i used the ADC-16 at uni)
picotech
http://www.picotech.com/data-logger.html
also good is "Street dyno" but i am yet to try it..
i reckon give it a go Very Happy better than no datalogger at all!
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Sun, 23 October 2005 08:37 Go to previous messageGo to next message
there's plenty of circuits available for such DIY dataloggers out there..... 1st semester of uni we did one....
kingmick
Banned by his request
moved to tamworth
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Sun, 23 October 2005 09:45 Go to previous messageGo to next message
id look at australian ones.remmeber the states are atleast ten+ years behind us in engine managment and that also includes dadta logging.go aussie you will be much happier.
mick
Starfire
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Mon, 24 October 2005 00:11 Go to previous messageGo to next message
Can you suggest anything local mick?
Ben Wilson
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Mon, 24 October 2005 05:40 Go to previous messageGo to next message
As above - If you can provide links for anything local for a similar price, I'll grab at least one.
sjsj
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Mon, 24 October 2005 09:24 Go to previous messageGo to next message
Another update. The locally available Picotech ADC-12 looks the goods Smile. Available at: http://www.emona.com.au/catalogue/Section_4/index. html
Though they want > $220AUS for it!! Yikes. Asked for the price for a Toymods forums group-buy, so waiting for an answer.
I think if it's over $150, I'm just gonna get the DataQ from the US is ($50US). Will see if it's cheaper on Ebay.
Cheery,
sjsj
Ben Wilson
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Tue, 25 October 2005 01:41 Go to previous messageGo to next message
IIRC the freight on those from the US is a killer, I was thinking about getting one a while ago.
sjsj
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Tue, 25 October 2005 02:00 Go to previous messageGo to next message
NOTE: Found the sampling rate is divided by the number of inputs used. So 14.4K/4 if using 4 inputs!!
More info.. there's another DataQ unit I missed in the mix. Nice feature is 12-bit resolution (4096 levels)
3/ DI-158U $99US
* 12-bit measurement resolution (ie: 2^12=4096 levels)
* Four ±10V or optional ±64V fixed differential inputs.
* Four digital bits for general purpose I/O.
* Two 0V to 1.25V digital to analog output ports.
* USB PC interface
* 14,400 samples/second
* Includes WinDaq/Lite Recording Software, WinDaq W
* Winner of Evaluation Engineering's 2004 Reader's Choice Award for Best Data Acquisition Product.
* Details at http://www.dataq.com/products/startkit/di158.htm
Cost delivered to Australia?
DataQ charge $30US to deliver to Sydney only via courier company DHL!! So the total cost then is:
1/ DI-194RS $24.95US + postage = $54.95US = $73 AUD
2/ DI-148U $50US + postage = $80US = $107 AUD
3/ DI-158U $99US + postage = $129US = $172 AUD
Postage costs scale from $30US per unit to $72 for 10 units! Though customs hit ya with fees as soon as you go > $250AUD using a courier!! Unless it's standard post in which the doco says is $1000AUD, though people say it's $500AUD.
Where to from here?
* Checking with the local AUS distributor http://www.turnkey-solutions.com.au to see if they can do a special price for toymods forum members. A dude there is doing the calcs now and I'll post up the info as soon as I receive it.
sjj
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Tue, 25 October 2005 03:22 Go to previous messageGo to next message
does EMS count for courier? i've recently sent a few things around the $4-500 makr and not beeen pulled up...
EMS is cheaper also..
the ADC-16 is a nice piece of hgear to work with, and the picologger is good software..
they are more exxy tho.. but 8 simultaneous channels Wink
sjsj
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Wed, 26 October 2005 15:59 Go to previous messageGo to next message
ADC-16 is the goods.
$AUD398.20 from these folks:
http://emona.com.au/Prices/Section%203%20&%204 %20PC%20Based%20&%20Data%20Acquisition.pdf
$AUD429 from here:
http://www.esis.com.au/Pico/Pico001.htm
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Wed, 26 October 2005 16:16 Go to previous messageGo to next message
fark thats cheap, we paid about $600 a few years ago for uni Wink
fwiw, you can hook up LM35DZ (iirc) precision temp sensors to it to measure deg C.. 10mV/C
i think some of the LM35's go up to 150?? but are around $10 each..
sjsj
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Fri, 28 October 2005 06:22 Go to previous messageGo to next message
Okay folks.. we can get the DataQ DI-158U and DI-148U at pretty good prices locally via http://www.turnkey-solutions.com.au
I'm interested in the DI-148U myself. $80 is pretty cheap for 8-analog 10-bit ports, 14.4k, USB, etc. Think that's probably good enough for my engine diagnostics.
> Date: Fri, 28 Oct 2005 15:21:58 +1000
> From: Mark Goulding <mcgo@turnkey-solutions.com.au>
> Subject: Re: Dataq blurb
> Hi Steve,
> Please find prices for DI-158U and DI-148U
> DI-158U $136 ex GST
> DI-148U $72 ex GST
> Local delivery costs will depend where and how they
> want the units sent(express post, standard mail etc).
> For GST Inclusive Price Add 10%
> <http://www.turnkey-solutions.com.au/glo_tts_tandc. htm>This
> quotation is subject to the Terms and Conditions
sj
MacroP
Binningup WA
Re: $25/50US real-time logger for O2,AFM/MAF/MAP,TPS,RPM found!! Fri, 28 October 2005 13:25 Go to previous message
oldcorollas wrote on Tue, 25 October 2005 11:22
Not classed as courier as far as I know. Packages seem to go straight through customs just like USPS stuff does, unlike those farken rip-off merchant couriers - like UPS,Fedex,DHL etc etc. EMS seems to be at least half the price of the couriers and take no longer to get here, if not quikcer. Same goes for USPS.
Previous Topic:YOUR opinions on 'what a ricer' is....
Next Topic:WHAT COLOR - WHAT PAINTWORk to USE ?3 tone - celica sample
Current Time: Sun Oct 18 11:54:24 UTC 2026
Total time taken to generate the page: 0.0081319808959961 seconds
