Toymods » Tech & Conversions » TA22 Brake and Suspension upgrade?
Blaze
TA22 Brake and Suspension upgrade? Sat, 11 January 2003 01:04 Go to next message
Hi there,
Just got a ta22, I am going to be pulling my Jet Ski around with it so I was wondering if I would need to upgrade the brakes and suspension at all? Any thoughts??
Jonny2TG
Tasmania
Re: TA22 Brake and Suspension upgrade? Sat, 11 January 2003 01:46 Go to previous messageGo to next message
Just get new shocks. Inspect or replace the brake pads regularly.
Slightly stiffer springs may be good also, as long as you also get good shocks.
juzzo84
Hornsby, N.S.W
icon10.gif  Re: TA22 Brake and Suspension upgrade? Sat, 11 January 2003 16:01 Go to previous messageGo to next message
if you are towing load, it may be a good idea to get something do in the braking department and get some sloted rotors and all new pads all round, just to give you that little extra bite, for those extra kilo's your carrying.
JUZZO
juzzo84
Hornsby, N.S.W
JUZZO
roadrunner
Hornsby, Sydney
Re: TA22 Brake and Suspension upgrade? Sun, 12 January 2003 07:07 Go to previous messageGo to next message
look into putting commodore front struts in. i am pretty sure they fit and trying this conversion myself.
t_temperley
Re: TA22 Brake and Suspension upgrade? Sun, 12 January 2003 08:06 Go to previous messageGo to next message
geeezus that sure would stop you in an awful hurry.
what model commodore strut are you using?
Redneck Rallysport
Jervis Bay
Re: TA22 Brake and Suspension upgrade? Sun, 12 January 2003 10:18 Go to previous messageGo to next message
Don't know about the Commodore struts, but the XT-130 Corona struts bolt straight in, and then gives you the option of better inserts than the TA-22. (I put RAV 4 Koni inserts in mine) The Corona disk is an inch bigger and still runs the same stud pattern as the TA-22. Only problem is that not all 13" wheels will fit around the caliper. (good excuse to go to bigger wheels)This setup worked well in the rally car.
Boris
Grega
melbourne.victoria.austra...
Re: TA22 Brake and Suspension upgrade? Sun, 12 January 2003 10:35 Go to previous messageGo to next message
is the chronos disk also ventilated as well? can you use the same TA22 spring/strut in the XT130 strut or do you have to go out and get a new spring/strut?
Redneck Rallysport
Jervis Bay
Re: TA22 Brake and Suspension upgrade? Sun, 12 January 2003 10:43 Go to previous messageGo to next message
The disk isn't ventilated, the strut tower will accomodate the spring (though mine was lowered), I am pretty sure however that the insert wont fit. I had my TA-22 towers modified to fit the bigger insert, so when I did the mod I already had the right inserts. It is however a cheap conversion, I picked up the full strut assembly (tower, insert, disk, caliper etc) from the wreckers for $90. The disks and pads where in good cond, and I could have just bolted the whole lot straight in, but my inserts and springs where better than the Corona ones.
Boris
mckejon
Re: TA22 Brake and Suspension upgrade? Sun, 12 January 2003 11:05 Go to previous messageGo to next message
Redneck Rallysport, did you use the strut top off the XT130 or your origional TA22 strut top? cos i tried to fit the xt130 top in a TA22 tower and it didn't fit.
Redneck Rallysport
Jervis Bay
Re: TA22 Brake and Suspension upgrade? Sun, 12 January 2003 11:12 Go to previous messageGo to next message
To be honest, I can't fully recall, I very well may have used the TA-22 ones, I did the mod about 18 mths ago, and have since sold the car. It is now racing at Hidden Valley in Darwin.
mckejon
Re: TA22 Brake and Suspension upgrade? Sun, 12 January 2003 11:49 Go to previous messageGo to next message
Oh, well thanks anyway. looks like its back to pick'a'part to do some more tinkering. Razz
Blaze
Re: TA22 Brake and Suspension upgrade? Sun, 12 January 2003 22:59 Go to previous messageGo to next message
Thanks for the info guys. i am lloking for something that is not going to cost too much money, and at the same time not cause me too much pain in modifying parts to fit. I haven't got the car yet so I will get back to you when I know a bit more on what I need.
saspeed
Re: TA22 Brake and Suspension upgrade? Thu, 23 January 2003 11:23 Go to previous message
I am now the proud owner of the TA22 in question and unfortunately it's still a long way from the racetrack due to pain in the butt 3SGTE conversion. (sorry redneck!!)
I just had a look at the strut towers and can see no evidence of modification so your struts should just bolt straight in.
I am going the hilux caliper/peugot rotor although I have heard that VN commodore discs/hubs (one part) will go straight on although this will change your stud pattern.
I have used the hilux calipers on previous racecar and they worked great with no overheating/fade and very minimal pad wear so they would be great on a road car !!
cheers.
Previous Topic:3s-gte(st185) into ta-23 conversion
Next Topic:Intercooler Pipes
Current Time: Fri Oct 30 12:19:46 UTC 2026
Total time taken to generate the page: 0.0045900344848633 seconds
