Toymods » Tech & Conversions » Any opinion/advice on a 1JZGTE swap into AE86?
BlakeNZ
Any opinion/advice on a 1JZGTE swap into AE86? Thu, 06 June 2002 07:52 Go to next message
The Toymods engine swop page lists this swop as possible,has anyone done it?Anyone got any opinions on it?The purpose is drag,with a bit of street.Thanks for any replies.
Re: Any opinion/advice on a 1JZGTE swap into AE86? Thu, 06 June 2002 08:28 Go to previous messageGo to next message
If you can make it fit, would be one hell of a drag car. IF they can fit a 2JZGTE into one in Japan, then you know its possible.
Do expect to be taking corners seriously though...will root up the weight balance royally.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Any opinion/advice on a 1JZGTE swap into AE86? Thu, 06 June 2002 09:39 Go to previous messageGo to next message
Putting it really bluntly, the only thing the sprinter really has going for it is its handling, so putting a 1J in it would be a bit of a waste in my opinion.
There's plenty of small, light RWD cars around that could fit a 1J (well, with as much effort as it would take to fit to a sprinter) why use a sprinter?
Re: Any opinion/advice on a 1JZGTE swap into AE86? Thu, 06 June 2002 13:12 Go to previous messageGo to next message
something like a TA22/RA23 celica would prolly be the go.
yogi got his weight down to about 800 i think he said ... allow another 100kg for the 1jz, you're looking at a 900kg car with potential for over 400 horsies...
plus they have an adjustable radiator support, and there are a few people who've actually done it whom you could ask about it
in any car like that tho, there's going to be lots of cutting and squeezing to try and get it in
Ribbo
Northern Beaches
Re: Any opinion/advice on a 1JZGTE swap into AE86? Thu, 06 June 2002 14:14 Go to previous messageGo to next message
I don't know about weight differneces but at the sprinter day there was a 1G sprinter and he said that it handles heaps good, can't remeber if he said it was actually better but he defenatly didn't say it was worse.
Re: Any opinion/advice on a 1JZGTE swap into AE86? Thu, 06 June 2002 14:28 Go to previous messageGo to next message
couldn't handle better unless he'd done other work.. 1G is a lot heavier than the stock sprinter engine
and the 1JZ is a lot heavier again, and because it's longer more of that weight is closer to the front of the car
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 02:27 Go to previous messageGo to next message
Ribbo wrote on Fri, 07 June 2002 12:14 AM
Perhaps you ought to take this guy's opinion with a grain of salt. I know people who reckon their stock Cortina/Gemini/random shitbox handles "heaps good". Smile
OPELGTBEAMS
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 02:42 Go to previous messageGo to next message
OOO try this no one does this mod and it works
get a BEAMS 3s-ge and turbo charge it its stock with about 220 hp as a 3s-ge design with a turbo the sky is the limit.
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 02:53 Go to previous messageGo to next message
Dude the gen 4 3SGE's have comp ratios around 11:1. Where are you going with turbocharging it?
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 02:57 Go to previous messageGo to next message
ok, this may be a very naive question, but I've never understood exactly what comp ratios are, and more importantly why you shouldn't turbocharge cars with very high comp ratios
BlakeNZ
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 06:02 Go to previous messageGo to next message
I was looking at a S13 silvia or a mid-80s BMW 3 series to slot the 1JZ into,but my mate suggested it would be a pity to move away from Toyota.(he drives a Supra TT,I drive a Soarer TT).
So i guess I am clutching at straws a bit looking at an AE86.I shied away from the early celicas due to their age,though I quite like the shape.Any other suggestions,Gentlemen?
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 06:50 Go to previous messageGo to next message
That's an easy one: MA61 Supra! They're about the same age as an AE86, but a big inline six like the 1JZ will fit quite easily. Take a look at my web site and you'll see how good a 2JZ looks in an MA61 engine bay! Smile
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 08:05 Go to previous messageGo to next message
There is a dude oer here in Perth who has an S2000 that is turbocharged. They have over 11.0:1 compression stock. Imagine with some boost shoved down its throat.
BigWorm
Turramurra, Sydney.
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 08:24 Go to previous messageGo to next message
For draven, compression ratio is the ratio between the volume in 1 cylinder before & after the stroke. So with 10:1, if the motor was a 2L 4cyl, the volume at bottom dead centre would be 500cc, and the volume left at top dead centre would be 50cc (500:50=10:1).
And the more the a/f mixture is being compressed, the bigger the bang when it's ignited, and the more power produced.
So if you're pumping in a mixture that is already compressed (with a turbo) then the compression ration should be reduced a little bit, or the turbo limited to mild boost settings, otherwise the engine will be under too much strain.
Some one may like to add something, or correct me, but that should give you a basic idea of C/R.
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 08:37 Go to previous messageGo to next message
Mk2 Corona + JZ series engine = sleeper.
fergo308
Eastern Sydney
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 11:59 Go to previous messageGo to next message
1JZ + AE86 = Pain.
if you want to put the engine into a toyota,I suggest you take Norbie's advice,and go for a *A60 celica/supra.
the bay is designed for a straight six.
the sprinter is designed for one thing alone-the 4AG.
going for a silvia isn't a bad idea,as it's virtually a bolt-in proposition to go from a CA18/Sr20 to an RB series 6cyl.
grab a skyline crossmember,and off you go! the cross member bolts straight to the silvia floorpan! no toyota swap will be that easy.
the 1JZ into an S13 would be painful,and for what? not much more power potential than you can get from working an RB25.
Ribbo:
Nathan has a beautiful car,but I reserve my judgement on it's handling. I just don't see how doubling the weight over the front wheels can give no ill handling effects.
as was said,one man's idea of top handling is another's idea of a boat ride. look at the americans...they wouldn't know a good handling car if you ran them over with one.
with a 4ag,the sprinter is damn close to a 50/50 balance.
how much heavier is a 1GGTE again? couple this with the fact that the 1G was in the 4A's normal position -in front of a std firewall-meaning more weight in front of the front axle line than usual,and I don't see how it could be unchanged.
I'd love to be proven wrong however,but I doubt that will happen.
Justin...
Re: Any opinion/advice on a 1JZGTE swap into AE86? Fri, 07 June 2002 13:32 Go to previous messageGo to next message
I thought so, just checking tho
and you can always reduce the weight at the font... move the battery, aftermarket front spoiler (apparently the stock celica one, and it's mounts, weigh 15kg)
BlakeNZ
Re: Any opinion/advice on a 1JZGTE swap into AE86? Sat, 08 June 2002 01:46 Go to previous messageGo to next message
Thanks Justin for your thoughts.I already have the 1JZ motor sitting waiting for a car,so this is why i want to go the 1Jz route.Besides,i regularly cane R33 Skyline coupes(1400kg) in my bulky Soarer-the Toyota motor is somehow better.
How much do these MA61 (or*A61) Supras weigh?I like the shape.
How much does a RA23 weigh?Who has got a six cylinder in a RA23?
Re: Any opinion/advice on a 1JZGTE swap into AE86? Sat, 08 June 2002 08:09 Go to previous messageGo to next message
uuuummmmm
matthew green <matthew@metrolink.net.au> has a 1jz RA23, but 1JZ celicas of any kind will run into similar issues, having similar size engine bays.
basically, you should be looking for a toyota that came stock witha 6-cyl engine, like the 5M or 7M supras
Re: Any opinion/advice on a 1JZGTE swap into AE86? Sat, 08 June 2002 08:23 Go to previous messageGo to next message
MA61 1340-80 kg, depending on options etc.
Re: Any opinion/advice on a 1JZGTE swap into AE86? Sat, 08 June 2002 08:36 Go to previous messageGo to next message
There are lots of pics of Matt Green's 1JZ-GTE RA23 Celica on my web site if you want to know what it looks like. Note that it weighs close to 1300kg now (ie not much less than a Mk2 Supra) and it can only manage a low 14 second 1/4 mile, so I wonder if all the trouble he went to was worth it in the end. And believe me, it's a BIG job to squeeze a JZ engine into a Celica engine bay!
Definitely put the engine into something designed for a six, like a Supra or a Corona MkII (as GT suggested). I actually really like that idea! Two-door MkII's actually look quite cool, but no-one would expect it to be fast... Smile
[Updated on: Sat, 08 June 2002 08:37]
Re: Any opinion/advice on a 1JZGTE swap into AE86? Sat, 08 June 2002 08:52 Go to previous messageGo to next message
I just got myself a 2 door Mk2 (MX23). Very straight with a bit of rust in L rear quarter panel. It is 60 kg lighter than the 4 door MX13 (1220 kg) and I now have a contact for a windscreen. This car IS the shit. 2JZ inside (soon).
Re: Any opinion/advice on a 1JZGTE swap into AE86? Sun, 09 June 2002 02:41 Go to previous messageGo to next message
I'm so jealous Razz
how much did it cost you?
Re: Any opinion/advice on a 1JZGTE swap into AE86? Sun, 09 June 2002 03:48 Go to previous messageGo to next message
gianttomato wrote on Sat, 08 June 2002 6:52 PM
2JZ inside (soon).
Mint!! I can't wait to see some pics.
IRA11Y
Club Member
Re: Any opinion/advice on a 1JZGTE swap into AE86? Sun, 09 June 2002 04:06 Go to previous messageGo to next message
Sprinter weight distribution from factually recorded weights as of yesterday!
front rear total
IRA11Y 540Kg 500Kg 1040Kg
Mos 540Kg 490Kg 1030Kg
Ribbo 540Kg 470Kg 1010Kg
remeber rear weight is subject to fuel load I had 3/4 tank Mos ran 1/2 and I didnt see Matt's gauge
all cars ran 4AGE engines
I would hate to see the front rear split with the 1J
and seeing as I have been staring at one of these engines all weekend I would definately not want to face trying to install it in to a sprinter, Im sure there would be firewall issues to start with let alone trying to mount it on the cross member.
icon10.gif  Re: Any opinion/advice on a 1JZGTE swap into AE86? Sun, 09 June 2002 05:14 Go to previous messageGo to next message
Have to get RWC and club rego on it with 4M. Then let the madness begin! It's the NA variant, but it's not as Toyota created it.hehehe
I have seen a 2JZGTE in an AE86, but it was an out and out drag car (featured in Options magazine). I still think the Mk2 Supra remains your best bet, followed by an older Crown/Corona Mk2. They are unloved cars!
OPELGTBEAMS
Re: Any opinion/advice on a 1JZGTE swap into AE86? Sun, 09 June 2002 07:11 Go to previous messageGo to next message
I still think you can not go wronge with a beams if you must use 3sgte piston to lower the pressure then increase your boost its easy to get 300 hp out of 3sgte and engine is super light
Re: Any opinion/advice on a 1JZGTE swap into AE86? Sun, 09 June 2002 23:01 Go to previous message
3s-gte is of course the best way to go comparitively light 4-cyl, and it's got LOADS of potential.
that and the fact that the sprinter weighs less than 1100kg, which quite limits what sort of turbocharged engine you can whack in it
Previous Topic:You guys think its bad to drive your car in Diag mode ?
Next Topic:Question about AFM adjustment screw on AE86?!?!
Current Time: Wed Nov 18 11:29:11 UTC 2026
Total time taken to generate the page: 0.008018970489502 seconds
