Toymods » Members Rides » Just a KE25 in lill old NZ
NZKE25
Wellington, NZ
October 2005
Just a KE25 in lill old NZ Mon, 24 October 2005 09:38 Go to next message
couple of pics
http://img.villagephotos.com/p/2004-4/698822/DSC00693.JPG
http://img.villagephotos.com/p/2004-4/698822/DSC00657.JPG
http://img.villagephotos.com/p/2004-4/698822/DSC00659.JPG
http://img.villagephotos.com/p/2004-4/698822/DSC00681.JPG
Current Setup
Rebuilt RWD 4age with slightly raised compression, oversize pistons with new bearings/rings approx 5,000km ago
4-2-1 extractors to about 2¼ mandrel bent exhaust.
Aftermarket cams
Polished cam covers
Polished oil/air separator
T50 gearbox
Hilux drive shaft
Celica diff
Front and rear sway bars
Adjustable height coilovers front
Stiffened springs and shocks with lowering blocks rear
Strut brace front
Cressida ventilated breaks front
14inch minilite mags with 195/60/14 tyres
Oil temp, oil level and voltage gauges built into dash
Next Mod
4AGZE
Front mount intercooler
gearbox rebuild
full re-spray
Link Plus ECU
Megz
Re: Just a KE25 in lill old NZ Mon, 24 October 2005 11:37 Go to previous messageGo to next message
VERY NICE mate... Was this for sale a few months ago on Trademe??
Very nice tho mate. Looks like a lot of mine and time has gone into it...
Go the 25's!
Michael
NZKE25
Wellington, NZ
October 2005
Re: Just a KE25 in lill old NZ Mon, 24 October 2005 20:45 Go to previous messageGo to next message
That it was Wink
Had done a CAM belt at the time and was unsure of what if any damage had been done. A bit of time, a donor head (purchased complete with VTIS for $80NZ) a few four letter words latter and it turned out all that had been done was two bent valve stems. Head was sent off to lose a bit of weight, replacement stems put in and clearances setup and she’s back on as good as new Wink
Still running stock ECU at this stage, however now that the choice has been made to go with the 4AGZE things are going to get interesting rather fast Wink
Also on the cards is a complete gearbox rebuild, don’t want to put the T50 behind the 4AGZE and have it go bang Wink
PMP020
January 2005
Re: Just a KE25 in lill old NZ Thu, 27 October 2005 10:16 Go to previous messageGo to next message
hahah mad.
i want dat sorta brake n suspension done to all my ke20s.
PMP would be a road warrior
and SUS would be king of the hills.
haha killa ride champ.
cheers scott
NZKE25
Wellington, NZ
October 2005
Re: Just a KE25 in lill old NZ Sat, 29 October 2005 02:13 Go to previous messageGo to next message
its not a bad set-up thats for sure Wink
the rear did have 50mm lowering blocks in there however inner guard rub was bit of an issue so its been changed to 25mm and handles much better.
I/C has been sourced off a mate, Mitsi ZR4 which should do the trick nicely Cool
Anastasios
Sydney, Earlwood
September 2005
Re: Just a KE25 in lill old NZ Sun, 30 October 2005 00:21 Go to previous messageGo to next message
hey i was wondering what u have in the front suspension n how much did it cost? u have coilovers? wat type thank because im looking to upggrade my ke55 suspension soon.
Spode
Tasmania
June 2005
Re: Just a KE25 in lill old NZ Sun, 30 October 2005 00:54 Go to previous messageGo to next message
Hey, awesome 25, just had a queston about the cooling system, it looks like the standard radiator I assume you would run a thermo fan of some discription. what are water temps like when at high RPM/in traffic?
Thanks,
Spode
NZKE25
Wellington, NZ
October 2005
Re: Just a KE25 in lill old NZ Sun, 30 October 2005 02:42 Go to previous message
I brought her as is so just happened to be in the right place at the right time Wink I thought I had a pic of the coilovers that I could show you but I dont Sad but from memory there was no spefic branding on them when I looked. The Rolla is 300Km's away from me in my mates workshop so next time I'm up there I'll take a decent look and some pics and let you know Smile
Spode - from memory its out of a Mitsi, slightly larger and more efficent than the original one Wink should be heading up next weekend to take G/box out as it needs a rebuild so I can confirm and supply more pics if you like
[Updated on: Sun, 30 October 2005 02:50]
Previous Topic:TA23 with 3TGTE
Next Topic:4agte's Aus Spec aw11 "4agte" project ** with new pics **
Current Time: Sat Nov 21 04:38:33 UTC 2026
Total time taken to generate the page: 0.0053079128265381 seconds
