Toymods » Tech & Conversions » VACUUM AT IDLE
stealth007008
perth
June 2005
VACUUM AT IDLE Tue, 25 October 2005 05:13 Go to next message
hey guys can u post how much vac. your car makes at idle particularly 7mgte owners.
Yian
Lwr Templestowe, Melbourne
Re: VACUUM AT IDLE Tue, 25 October 2005 05:20 Go to previous messageGo to next message
20ish? 21.. around there
SilverGhost
Re: VACUUM AT IDLE Tue, 25 October 2005 05:43 Go to previous messageGo to next message
unless you have a fast idle actuator or anything operating....basically a warm motor at normal idle, most cars should hover around 20 regardless of engine type....
I did say most Very Happy
stealth007008
perth
June 2005
Re: VACUUM AT IDLE Tue, 25 October 2005 05:52 Go to previous messageGo to next message
so do u think 16-18 is too low? if so what affects the vac readings? besides leaks
Yian
Re: VACUUM AT IDLE Tue, 25 October 2005 05:57 Go to previous messageGo to next message
Revs?
SilverGhost
Re: VACUUM AT IDLE Tue, 25 October 2005 05:59 Go to previous messageGo to next message
if its at normal idle speed for that motor then the only real cause could ve a vac leak....
unless your compression is shot...
nick.parker
January 2005
Re: VACUUM AT IDLE Tue, 25 October 2005 09:00 Go to previous message
My 4AGZE with standard cams & cam timing was about 22mmHg.
With 267 cams and on current setting it pulls about 20mmHg - basically has a 'stock' idle.
[Updated on: Tue, 25 October 2005 09:03]
Previous Topic:1G-FE Wiring Diagram ecu - engine
Next Topic:RA60 clutch help......
Current Time: Fri Nov 20 10:25:02 UTC 2026
Total time taken to generate the page: 0.0061500072479248 seconds
