Toymods » Tech & Conversions » air con help needed in soarer
soarted bruva
May 2005
air con help needed in soarer Tue, 25 October 2005 07:53 Go to next message
i have a z20 soarer with the 1jz in it and have no air con gear. Just needing to know which stuff i can use from the same model soarer and which stuff i need to get compatable for the 1jz motor itself? Confused
sideshow
Re: air con help needed in soarer Tue, 25 October 2005 10:35 Go to previous messageGo to next message
use all soarer bits except for the 1j a/c compressor
doin the wiring using all 1j bits will be a massive job
its much easier to run std soarer a/c system and wiring then just wire up the 1j compressor to the soarer
soarted bruva
May 2005
Re: air con help needed in soarer Tue, 25 October 2005 12:51 Go to previous messageGo to next message
Hi Jim,
Thanks for the advice, dunno why i didn't think of asking you. So i need to track myself down a 1j compressor and then what are the names of the other parts required that come from a soarer as i'm not too clued up on what parts make up the air con system, ie condensor etc??
I still gotta fix you up for sorting out me loose wire on my soarer, haven't forgotten. If your able to i might get ya to hook up my air con for me if thats cool.
Joel
[Updated on: Tue, 25 October 2005 12:55]
Matt M
Sunshine Coast
January 2005
Re: air con help needed in soarer Wed, 26 October 2005 09:37 Go to previous messageGo to next message
mate wouldn't the A/C compressor still be on the 1j? or did you have it taken off and a different belt setup put on? just thinking that with the mutli rib belt that goes all over everything then it would need the a/c compressor or a replacement item to keep the belt taught? or am i on glue?
soarted bruva
May 2005
Re: air con help needed in soarer Wed, 26 October 2005 12:14 Go to previous messageGo to next message
firstly i bought the car with the 1j in it and obviously no air con and secondly i have to say i'm not really qualified so to speak to know if it's still on there but i shall now get someone who knows what they're looking at to tell me cos by your description it may well be on there yeah. I don't even know where the compressor goes or what it looks like so i guess you could say i'm pretty clueless in regards to this matter. Thanks for your input Matt, appreciated
Matt M
Sunshine Coast
January 2005
Re: air con help needed in soarer Wed, 26 October 2005 13:05 Go to previous messageGo to next message
ok mate i am doing the 1j conversion in my gz20 at the moment and having a bullsh*t load of drama... but my air con compressor is still there...
have a look mate...
on the right hand side i think.. its been a while since i looked and i am a n00b at this too... pretty sure it is lower right hand side when looking from front of car tho...
good luck mate
matt
soarted bruva
May 2005
Re: air con help needed in soarer Tue, 01 November 2005 12:34 Go to previous message
had a look and didn't seem to be there which to make sure i had someone to confirm so it has been removed with the rest of the gear. If anyone has a 1j compressor for salr or any of the other air con parts from a standard z20 soarer let me know, thanks
Previous Topic:4AGE heat problem :(
Next Topic:ae86 front panels
Current Time: Wed Nov 18 04:17:08 UTC 2026
Total time taken to generate the page: 0.0056071281433105 seconds
