Toymods » Tech & Conversions » 18r-c timing gear
simulant
Sydney - Northern Beaches
18r-c timing gear Sat, 11 January 2003 08:23 Go to next message
anyone know if the timing gear on an 18r-c can be accessed without removing the head? My problem is that one of the chain guides is loose (buggered if I know where the bolts have gone) with the rocker cover off you can actually get soem pliers onto it and move it about, thus the timing is pritty stuffed and it's very rately. I was thinking might be able to just drop the sump, any sergestions???
stradlater
Arthurs Creek, Victoria
Re: 18r-c timing gear Sun, 12 January 2003 02:17 Go to previous messageGo to next message
You can get the timing cover off without dismantling the rest of the motor, however you can't get it back on properly, I should know, I've fucked a few. Just take the head off, it's not hard, and then fix your timing and put the head back on. The head bolt tension on the 18r head isn't crucial, considering the rings and so forth are probably screwed anyway. If you fuck the head I have two spare here anyway
M.W.P.
Rocky Mountains, Canada
Re: 18r-c timing gear Sun, 12 January 2003 03:57 Go to previous messageGo to next message
Care to explain more stradlater?
simulant
Re: 18r-c timing gear Sun, 12 January 2003 05:26 Go to previous message
I had a feeling that would be what I'd have to do, it's more of a matter of finding the time to do it and I'm thinking a new head gasket wont be too cheap either,
Previous Topic:removin aircon in sprinter
Next Topic:1G-GZE Corona
Current Time: Tue Oct 20 23:51:50 UTC 2026
Total time taken to generate the page: 0.028678894042969 seconds
