Toymods » Tech & Conversions » Supercharger piping
Windex
Melburn!
June 2005
Supercharger piping Wed, 26 October 2005 02:41 Go to next message
Gday,
Am looking into doing a SC14 setup on my 3SGE and was wondering would it be possible to get away with not using metal piping for all the SC charge pipes?
Also I was wondering about design. What is the general flow of a SC system, I am looking at running the SC -> cooler -> then straight onto the existing intake piping manifold. I have a TPS system on it currently, which side of the charger should this be?
All
Ben Wilson
Re: Supercharger piping Wed, 26 October 2005 03:10 Go to previous messageGo to next message
You should have the throttle body before the supercharger. You might be able to get away with a big BOV if you run the throttle body after, but, you might have problems.
Other than metal, what are you thinking about making the pipes out of?
Re: Supercharger piping Wed, 26 October 2005 03:41 Go to previous messageGo to next message
if throttle is before the SC, ALL piping must be metal or else it will collapse under the vacuum of the SC...
even 3-4" sections of silicon pipe could get sucked in.
maybe Wink
Henn
Rosanna, Melb
Re: Supercharger piping Wed, 26 October 2005 04:04 Go to previous messageGo to next message
oldcorollas wrote on Wed, 26 October 2005 13:41
True. Thought it's not the SC which makes the vacuum, it's just purely because it's post TB.
Not necessarily metal, but the piping must be rigid and so doesn't give you many other options... maybe PVC if you want to be dodgy about it.
Hen
Windex
Melburn!
June 2005
The throttle body can be moved easily enough, which positioning is better?
I was thinking of going with silicon tubing, due to being able to purchase myself and fit myself(no welding skills).
Bill, your site is awesome!
Ben Wilson
Re: Supercharger piping Wed, 26 October 2005 04:14 Go to previous messageGo to next message
Silicon turbo doesn't like vacuum.
Autospeed had an article about using copper pipe which might be easier.
How do you plan on mounting a supercharger if you can't weld?
Windex
Melburn!
June 2005
Re: Supercharger piping Wed, 26 October 2005 07:53 Go to previous messageGo to next message
Its going to sit on my lap. Smile No I have a friend that is going to make some mounts up for me, but I am not sure if I could stretch that to piping, but will try if not I will find someone to pay to do it.
terra
July 2005
Re: Supercharger piping Wed, 26 October 2005 07:58 Go to previous message
very thick reinforced rubber hose (like radiator hose) work it can.
why not use pre-bent bits of metal pipe? buy them at exhaust shop if machine shops and factories you cannot find.
Previous Topic:ke70 3sge
Next Topic:4agte turbo oil leak
Current Time: Fri Nov 20 20:56:36 UTC 2026
Total time taken to generate the page: 0.0041449069976807 seconds
