Toymods » Tech & Conversions » T18 Wiring problem
nabs478
T18 Wiring problem Wed, 26 October 2005 22:32 Go to next message
I have just bought a T18 and neither of the indicators work. Both of them come on if the hazard switch is turned on tho. I pulled apart the column and found that the switches for the indicators and hazards are both in the same assembly, the combination switch, and assumed that was fucked. I replaced it and the problem is still there.
I would assume that is would mean that theres probably a relay somewhere thats not working or something but not sure. If any one has any ideas of where to go from here all advice would be appreciated, comments like "sounds like a prick" or "good luck man" will not.
Henn
Rosanna, Melb
Re: T18 Wiring problem Thu, 27 October 2005 00:41 Go to previous messageGo to next message
Mullet boy, I have a Sprinter body manual with a full wiring diagram in it. I reckon it'd be the same or very similar to a T18, so you could take a look at that if I were willing to lend it to you... which I'm not.
Hen
nabs478
Re: T18 Wiring problem Thu, 27 October 2005 07:22 Go to previous message
well I already read the section of your special book which went something like...Bok Bok Bok Bur-gurgh, Bok bok...If I remember corretcly
If I heavnt sorted it out by the time you get back from Date-ville I'll give you a bzz
If any other poofs know what to do then tell me
Previous Topic:4a wanted for ae 82 seca
Next Topic:Conversion Help
Current Time: Sat Oct 31 03:53:49 UTC 2026
Total time taken to generate the page: 0.0046529769897461 seconds
