Toymods » Tech & Conversions » SA63 Diff
customSA63
Adeliade
February 2005
    NA
SA63 Diff Thu, 27 October 2005 07:39 Go to next message
hey all my diff went today i belive.
what fun, so i was wondering does any one know how easy it is to swap over the crapy open wheeler/drumbrake back end to the MA61 set up at the back like for example if i pulled everything of from the drive shaft back including brakes and arms and everything will the supra diff centre arms and brakes all bolt up into the same place or do i have to weld and get dirty.
and if anyone has the whole set up from a MA61 for sale let me know if you want to sell it and if you will ship or if your in adelaide even better.
matt
Smile
wilbo666
Re: SA63 Diff Thu, 27 October 2005 10:36 Go to previous messageGo to next message
If you get the whole MA61 rear subframe intact it will bolt up.
You will also need a MA61/RA65 Drive shaft (rear section) as it is shorter (shorter! *slaps head*). You will also need a MA61 brake bias valve so that the rear brake bias is correct.
[Updated on: Fri, 28 October 2005 00:41]
Re: SA63 Diff Thu, 27 October 2005 23:00 Go to previous messageGo to next message
wilbo666 wrote on Thu, 27 October 2005 18:36
You will also need a MA61/RA65 Drive shaft (rear section) as it is longer.
Don't you mean shorter, given that the T-series diff isn't as long?
wilbo666
Re: SA63 Diff Fri, 28 October 2005 00:40 Go to previous messageGo to next message
justcallmefrank wrote on Fri, 28 October 2005 09:00
Yep I am a dong, edited it....they are different tho Razz
Re: SA63 Diff Fri, 28 October 2005 00:51 Go to previous messageGo to next message
I know Smile My povo spec GA61 had a T-series Razz
wilbo666
Re: SA63 Diff Fri, 28 October 2005 03:39 Go to previous messageGo to next message
justcallmefrank wrote on Fri, 28 October 2005 10:51
I know you know, now be shush Razz
How was that indy thing by the way?
customSA63
Adeliade
February 2005
    NA
Re: SA63 Diff Fri, 28 October 2005 12:10 Go to previous messageGo to next message
ok i have decided that whole set up is to expensive so i was wondering does a ma61 centre bolt straight in to the sa63 and the disk brakes for the rear end can i take of the drums and bolt the disk brakes straight up or am i day dreaming.
matt
Very Happy
RA65 Sleeka
Re: SA63 Diff Sat, 29 October 2005 02:01 Go to previous messageGo to next message
at u pull it down south ther is a crown there with the same sub frame as the ma61. as it has disks but no lsd this would be a good brake up grade for the sa63 Smile
then just have a look around for a lsd
i might be able to get one for a good price but the clutchs will need to be tighten up
customSA63
Adeliade
February 2005
    NA
Re: SA63 Diff Sat, 29 October 2005 09:04 Go to previous messageGo to next message
hey all i fixed the brakes up so now the drumies are like new.
so alli need now is a diff i have thought about it and i only want the standard sa63/ra65 diff save money and time so if anyone has got the diff centre for that model and wants to sell.
that would be greatly appreciated i need one asap that is the only problem.
matt
Smile
ps all i need is the centre diff cheers Very Happy
Re: SA63 Diff Sat, 29 October 2005 09:52 Go to previous messageGo to next message
I highly doubt the Crown subframe will be the same as the MA61. Like the MX73 Cressida, it will be close, yet subtley different. The F-series centre will not bolt to the T-series subframe, they are different. Your best bet is still to get the entire MA61 rear subframe, or if you are worried about cost, as an interim measure, get an RA65 subframe and get an LSD later.
Re: SA63 Diff Sun, 30 October 2005 07:47 Go to previous message
Or if you just want to fix the car, get another SA63 diff and bolt it in. Should be cheap as chips from the wreckers.
The RA65 diff is an F series, same as the MA61, so it won't bolt it.
Previous Topic:JZZ30 Soarer into GZ20
Next Topic:r154 gearbox issues.
Current Time: Sun Oct 25 04:35:18 UTC 2026
Total time taken to generate the page: 0.007343053817749 seconds
