Toymods » Tech & Conversions » 3tgte...wirring in fuel pump...
freakincage_com
north brisbane
3tgte...wirring in fuel pump... Thu, 27 October 2005 09:55 Go to next message
ey guys i also need help with wirring in my fuel pump...does the 3tgte ecu control the pump?? or is it thru a switch in th AFM>
???i currently jus hav it hooked up to a togle switch...illegal....i need a tackametric relay...but i saw on the 3tgte wirring diagram..sumting bout a switch in the AFM...but the wires'z just end in the diagram...any help would b apreciated...thanks!!!ps yes im keepin it!!!hehe
wilbo666
Re: 3tgte...wirring in fuel pump... Thu, 27 October 2005 11:43 Go to previous messageGo to next message
Engines with AFM's generally have a Circuit Opening Relay (COR) so that the fuel pump gets turned off when the engine stops.
The COR relay sends power to the Fuel pump when the starter circuit is energized (i.e. during cranking), and the flap in the AFM when open provides power to the fuel pump.
Many cars have circuit opening relays that you can easily acquire from the wreckers Smile
Re: 3tgte...wirring in fuel pump... Thu, 27 October 2005 23:47 Go to previous messageGo to next message
yeah thats right, 3tgte uses a circuit open relay, with start signal and afm switch as a trigger.
freakincage_com
north brisbane
Re: 3tgte...wirring in fuel pump... Fri, 28 October 2005 07:39 Go to previous message
ah ok,so how do i wire it in???
Previous Topic:A/C problem...Any help appreciated
Next Topic:Peugot 604 discs - Where can i get them? DBA not making any for 2mths
Current Time: Fri Nov 20 06:43:52 UTC 2026
Total time taken to generate the page: 0.0048990249633789 seconds
