Classifieds » Engines, Accessories and other Mechanicals » FS: 4age Oil Cooler Setup!!!! SOLD
Big T
FS: 4age Oil Cooler Setup!!!! SOLD Thu, 27 October 2005 14:35 Go to next message
Hey everyone. I've got for sale an oil cooler setup for a 4age. This is the stock setup and comes with a thermostatic sandwich plate for the block, oil cooler and a bit of oil cooler hosing (you'll just need another one for the return/feed). I can also probably source the appropriate sump needed for the return line as well.
The price: $100 without the sump or $120 with.
Some pics:
http://img437.imageshack.us/img437/1010/oilcooler019gr.jpg
Both sides of the cooler are in great nick. I straightened any bent fins as best as i could... an extremely tedious job Laughing
http://img437.imageshack.us/img437/3746/oilcooler57rx.jpg
http://img437.imageshack.us/img437/8554/oilcooler69le.jpg
[Updated on: Mon, 31 October 2005 10:23]
raptor22785
September 2005
Re: FS: 4age Oil Cooler Setup!!!! Thu, 27 October 2005 15:16 Go to previous messageGo to next message
Don't wanna sound stupid, but whats the benifits of cooling the oil other than temp reduction?
psychofox
Wollongong, NSW
Re: FS: 4age Oil Cooler Setup!!!! Thu, 27 October 2005 21:44 Go to previous messageGo to next message
errr....that is the prime benefit of an Oil Cooler. Other than that I suppose you can run about 200mls more oil with this setup (maybe not even that).
Big T
Re: FS: 4age Oil Cooler Setup!!!! Thu, 27 October 2005 23:07 Go to previous messageGo to next message
Taken from the Permacool Website
Engine Oil Coolers
Almost one third of the heat generated by the engine must be removed by the vehicle's two cooling systems. That's correct, your engine has two cooling systems. (1) The top of the engine: the area around each cylinder in the engine block, the combustion chamber areas in the cylinder heads and the intake manifold, dispel heat through the engine's radiator coolant system. (2) The rest of the engine: the crankshaft, bearings, camshaft, lifters, connecting rods and pistons are only cooled by engine oil.
The ideal operating range for engine oil is 180°F through 200°F. While operating within this range, the oil works as a lubricant, coolant, and cleansing agent in the engine. Modern engines generally run with radiator coolant temperatures between 200°F and 220°F with oil temperature ranges between 20°F and 75°F HOTTER. In other words, when the engine is performing flawlessly, the engine oil is already overheating! Oil that exceeds 220°F rapidly loses its ability to lubricate and cool causing accerlerated fatigue and premature component failure.
Perma-Cool® Engine Oil Coolers can reduce the oil temperature to between 180°F to 200°F and keep it there. Benefits are:
Penguins
* Longer engine life
* Reduced heat load on engine and radiator
* Increased oil system capacity
* Lower under-hood temperatures and more!
If you spend any time in stop-and-go traffic, do any kind of towing, drive in a hot climate, or frequently use your air conditioning, your engine needs a Perma-Cool® Engine Oil Cooler!
Eddie.
BTW: Mods... if i wasn't supposed to cut/paste from their website, just let me know and i'll edit the post.
rthy
Melbourne - NthSubs
Re: FS: 4age Oil Cooler Setup!!!! Thu, 27 October 2005 23:18 Go to previous messageGo to next message
does it come with the sump return feed thing?
edit: just read it lol
[Updated on: Thu, 27 October 2005 23:20]
raptor22785
September 2005
Re: FS: 4age Oil Cooler Setup!!!! Fri, 28 October 2005 00:50 Go to previous messageGo to next message
Thanks, just the info i wanted to know!
Big T
Re: FS: 4age Oil Cooler Setup!!!! Fri, 28 October 2005 09:31 Go to previous messageGo to next message
All pms replied to
Eddie.
Big T
Re: FS: 4age Oil Cooler Setup!!!! Sun, 30 October 2005 22:01 Go to previous messageGo to next message
Cmon people. You've got till Friday this week to buy it whole as i've had an offer to split the kit up.
Eddie.
4agte
Toronto, Downtown
Re: FS: 4age Oil Cooler Setup!!!! Sun, 30 October 2005 22:31 Go to previous messageGo to next message
you have a pm
Big T
Re: FS: 4age Oil Cooler Setup!!!! Mon, 31 October 2005 10:23 Go to previous message
SOLD!!!
Previous Topic:Group buy for 600HP Turbo kit for 1JZ/2JZ
Next Topic:WTB: Sprinter Tailshaft or Gearbox Yoke
Current Time: Thu Oct 15 10:42:12 UTC 2026
Total time taken to generate the page: 0.0073609352111816 seconds
