Toymods » Tech & Conversions » is it possible to turn an 18rc twincam?
FNK11Y
queensland
icon5.gif  is it possible to turn an 18rc twincam? Thu, 27 October 2005 15:59 Go to next message
im not much of an engine guru
but can the head or something of a 18rg be taken out
and fitted to an 18rc to turn it twin cam?
sorry if i used any wrong wording Razz
i just want to see if i can get
some more outa my 18rc but i couldnt be bothered
going through an engine swap or anything right now
ra40coupe
May 2005
Re: is it possible to turn an 18rc twincam? Thu, 27 October 2005 20:45 Go to previous messageGo to next message
do a search, this has been covered lots.
yes it can be done, but its easier to just source an 18rg
people100
Rocklea qld
Re: is it possible to turn an 18rc twincam? Fri, 28 October 2005 09:59 Go to previous messageGo to next message
dont tell him its possible (although in theory it is). the answer is NO. (just saying that to say you the headaches)
willwal98
Toowoomba
Re: is it possible to turn an 18rc twincam? Fri, 28 October 2005 16:17 Go to previous message
although the bottom end is very similar the pistons are different (quite a bit less compression) so you would need to get new pistons or find 18r-g ones anyway. And if you have found a head plus all the other bits and pieces that are different(there are quite a few including the front engine convers, thermo housing, mainifolds etc) you will probably have found a complete engine anyhow. The best be is to get a full 18r-g. If it needs rebuilding it is possible to use some 18r-anything parts from the bottom end to complete your engine. I used some con-rods and a crank a dizzy and an oil pump from an 18r-c in my 18r-g build and never had issues. Upgraded to electronic dizzy and EFI not too long after and it was a good power boost. There are different 18r-g heads arround mainly ports and valves that differ.
Previous Topic:paint stripper that can be used on rubber?
Next Topic:AE86 digital dash conversion help
Current Time: Fri Nov 20 04:56:57 UTC 2026
Total time taken to generate the page: 0.0056881904602051 seconds
