Toymods » Tech & Conversions » yamaha head
1JZCressida
August 2005
yamaha head Fri, 28 October 2005 09:40 Go to next message
A friend who owns a 3sge celica, noticed that yamaha was cast into the head. He checked out other 3sge's and they didnt have it. Can anyone explain, is this a rare head?? is there an increase in h/p.. thanx heaps.. Smile
I know that yamaha has done alot of work with toyota like 18rgu's and 1jzs but ive never heard of it with 3sges....
Re: yamaha head Fri, 28 October 2005 10:02 Go to previous messageGo to next message
All the 3S heads are from Yamaha!
Jorrs
Coffs Harbour
Re: yamaha head Fri, 28 October 2005 14:14 Go to previous messageGo to next message
yeh man 3s heads are toyota, maybe u didnt look ahrd enough on the other ones, wat yr are the others and wat yr is your mates ?
Re: yamaha head Fri, 28 October 2005 14:28 Go to previous messageGo to next message
Aren't only the GE heads Yamaha, and the FE head Toyota?
Jorrs
Coffs Harbour
Re: yamaha head Fri, 28 October 2005 14:31 Go to previous messageGo to next message
no idea bout FE ? never had a look at one, prob true ? someone with a FE (god help u ) have a look Razz
RWDboy
Re: yamaha head Fri, 28 October 2005 15:09 Go to previous messageGo to next message
afaik (and this could be partly bullshit) Early Gen 1 3S-GE heads were stamped with Yamaha on them, there is no performance difference between a Yamaha stamped or non-stamped head. Design of the cast was originally by Yamaha and Toyota stopped putting the Yamaha stamp on it when they started doing the manufacturing/casting in house.
I think this is a common theme with all 3S-GE heads. As my ST165 has Yamaha stamped on it, as do some SW20's most ST185s etc etc.
willwal98
Toowoomba
Re: yamaha head Fri, 28 October 2005 16:24 Go to previous messageGo to next message
yamaha + toyota = fun
GTtwin
Newcastle, Australia
August 2005
Re: yamaha head Sat, 29 October 2005 23:08 Go to previous messageGo to next message
I think your right CrUZsida, FE heads are Toyota and GE are Yamaha. The only exception is 2JZ-GTE, its a Toyota designed head. Hence the popularity of building 1.5JZ's in Japan as the Yamaha 1JZ-GTE Head flows better up high.
Re: yamaha head Sun, 30 October 2005 07:54 Go to previous messageGo to next message
GTtwin wrote on Sun, 30 October 2005 09:08
This is a popular myth, as usual started by the yanks. Rolling Eyes Both the 1JZ-GTE and 2JZ-GTE heads are designed by Yamaha, as are all performance-oriented Toyota cylinder heads. There is no significant difference in flow rates between them.
Re: yamaha head Sun, 30 October 2005 07:57 Go to previous messageGo to next message
"4th gen" (or whatever) ST215 3SGTE has at least a yamaha sticker on it...
GTtwin
August 2005
Re: yamaha head Sun, 30 October 2005 08:09 Go to previous messageGo to next message
Norbie wrote on Sun, 30 October 2005 18:54
Aha, another myth de-bunked. So why the hell do they do it?
Re: yamaha head Sun, 30 October 2005 08:14 Go to previous messageGo to next message
Coz the price of a new 2JZ block is the same as a 1JZ block from Toyota.
And it doesn't require any electrical changes since you are retaining the 1JZ head.
Hence, a 'free' 500cc
Re: yamaha head Sun, 30 October 2005 08:15 Go to previous message
If you already have a built 1JZ with aftermarket cams, manifolds, turbos etc and you want to upgrade to 3.0L, it's cheaper and easier to build a 1.5JZ than swap in a 2JZ. This is because the manifolds and related hardware aren't compatible between the 1JZ and 2JZ.
Previous Topic:1G identifcation
Next Topic:JZZ30 Soarer into GZ20
Current Time: Sat Oct 24 09:58:03 UTC 2026
Total time taken to generate the page: 0.021559953689575 seconds
