Toymods » Tech & Conversions » supra 5 stud wheels
celicamad85
Banned member
supra 5 stud wheels Sun, 12 January 2003 05:29 Go to next message
gday i am using ma70 discs and calipers in my 1uzfe ta22
my question is........is all toyota 5 stud wheels the same stud pattern ??
because if not this will limit my choice in diffs and i will most likely opt for a cut down ford 9inch as they have the same pattern i know that for sure
Re: supra 5 stud wheels Sun, 12 January 2003 06:13 Go to previous messageGo to next message
I'm pretty sure all the 5-stud Toyotas are 5 x 114.3 which as you said is the same as Ford.
ed_ma61
Lost in the K hole
Re: supra 5 stud wheels Mon, 13 January 2003 01:45 Go to previous messageGo to next message
PCD is the same (5x114.3) but centre holes are different. toyota is 67mm (i think) ford is bigger. need to machine out toyota wheels to fint onto a ford axle.
ed
Re: supra 5 stud wheels Mon, 13 January 2003 03:09 Go to previous messageGo to next message
So what happens if you want to put Ford wheels on a Toyota axle?
Re: supra 5 stud wheels Mon, 13 January 2003 04:12 Go to previous messageGo to next message
You need to make a washer to take up the gap, that way all the load is taken by the axle rather than the wheel studs. Make it out of some aluminium to keep unsprung mass down.
ed_ma61
Lost in the K hole
Re: supra 5 stud wheels Mon, 13 January 2003 05:02 Go to previous messageGo to next message
'collar' is probably a less decieving term than 'washer'.
basically the collar just works to step your centre mounting shoulder out from 67mm (toyota) to XXmm (ford)
ed
wizzfizz2097
Re: supra 5 stud wheels Mon, 13 January 2003 07:48 Go to previous messageGo to next message
to answer a question... i dont beleive ALL toy stud patterns are the same, unless your refering to older ones than mine
Re: supra 5 stud wheels Mon, 13 January 2003 08:50 Go to previous messageGo to next message
Wait, I forgot ones, some of the cars are 5 x 100 as well, not as many as the 5 x 114.3, but some.
Re: supra 5 stud wheels Mon, 13 January 2003 09:08 Go to previous messageGo to next message
AFAIK all RWD 5-stud Toyotas are 5x114.3 (or 5x4.5" if you prefer). The FWD ones are 5x100mm.
celicamad85
Banned member
Re: supra 5 stud wheels Mon, 13 January 2003 09:20 Go to previous message
thanks for the input guys !
i have bought a ford 9 inch now so there is no going back, the plan is to machine the thread down to the same thickness as the toyota stud and retap the thread which is pretty easy, the hard part is going to be all the cutting and welding i have to do to make this fit !!
wayne
Previous Topic:Gearbox rebuilders
Next Topic:73 ta22 celica... bulb or beam type?
Current Time: Fri Oct 16 15:49:37 UTC 2026
Total time taken to generate the page: 0.025641918182373 seconds
