Toymods » Tech & Conversions » TA22 - How Hot does it run?
Grega
melbourne.victoria.austra...
TA22 - How Hot does it run? Sun, 12 January 2003 05:49 Go to next message
Okies. My 2T (yes i know) after changing the coolant thermostat and top radiator hose now runs just below 210F.
The thermostat opens at 192F. So would this be considered NORMAL?
i'd *almost* accept it as being normal, except the needle is like 1/2 to 3/4 up the gauge! WTF?
any ideas/comments/flames/abuse appreciated.
[Updated on: Sun, 12 January 2003 05:49]
t_temperley
Re: TA22 - How Hot does it run? Sun, 12 January 2003 06:06 Go to previous messageGo to next message
Ummm according to the 2t/2tg engine manual it should open at between 80.5 and 83.5 degrees celcius (177 and 182 degrees ferrenheight)
So umm no i guess it isnt normal Confused
dont ask me how hot my engine runs my guage doesnt work and about 1/4 of my radiator core is AWOL Sad
munki
Gold Coast
Re: TA22 - How Hot does it run? Sun, 12 January 2003 08:55 Go to previous messageGo to next message
buy a new thermostat your engine is running way too hot. im sure it is not opening properly.
I would think it should be a 1/4 temp for normal driving with the cooling system in good condition.
Redneck Rallysport
Jervis Bay
Re: TA22 - How Hot does it run? Sun, 12 January 2003 10:12 Go to previous messageGo to next message
My TA-22 Rally car would only operate at those temp during competition, during normal driving the temp would sit rock steady at 1/4, could be you have some work to do.
Boris
Grega
Re: TA22 - How Hot does it run? Sun, 12 January 2003 10:33 Go to previous messageGo to next message
um, yeah, it is a new thermostat thats the thing!
although, for what it cost it might be worth trying another one.
before i started any of this it would be sitting over the 180 degree mark as it was - now its way above. methinks my radiator might be blocked also - prolly worth a looksee...
thanks for the replies guys... Smile
BigBadBenny
Brisbane, Queensland
Re: TA22 - How Hot does it run? Mon, 13 January 2003 11:58 Go to previous messageGo to next message
flush out your radiator with the garden hose and see how it goes.
if it seems it top shape the next port of call is the water pump dieing.
Classique71
Colac, Victoria
Re: TA22 - How Hot does it run? Mon, 13 January 2003 12:08 Go to previous messageGo to next message
the thermostats opening way too late - like the other guys have said - mine never gets over 1/3 on the guage - even after very heavy footed driving ..
somethings not good here - other possibility would be a blockage in the actual motor/head ?
munki
Gold Coast
Re: TA22 - How Hot does it run? Mon, 13 January 2003 12:13 Go to previous messageGo to next message
before you fit the thermostat it is a good idea to flush your system to hopefully get rid of any gunk that cloged the thermostat in the first place. When you do this check the pipes to the radiator if they r stuffed this is an ideal spot for gunk to fall into your system.
How good is the water pump?
BigBadBenny
Re: TA22 - How Hot does it run? Mon, 13 January 2003 12:14 Go to previous messageGo to next message
lol mine doesn't even get to the first mark on the gauge!!!
Cucumber on wheels it is.
Modified three core torana radiator with twin ten inch thermos keeps the hybrid beast cool.
Now some of you might think this is to cool, but I have a second temp guage coming from the side of the block , sit's at about 75 to 80 degrees, and my thermostat opens at 72.
so big thumbs up to my upgrade I'm really happy with it.
Grega
Re: TA22 - How Hot does it run? Mon, 13 January 2003 13:14 Go to previous messageGo to next message
yeah when i pulled out the radiator i flushed it (i constructed a tool that uses hose and compressed air to force the gunk out) ran that thru the radiator and then ran the hose thru the engine (with thermostat removed) to flush out the block/head - water went in cleana and came out clean no issues.
water pump - i have no idea, but, am thinking that it might be on its way...how to tell? when the thermostat is opening i can see the water flowing (albeit quite slowly) thru the radiator cap and thats about it..
Redneck Rallysport
Jervis Bay
Re: TA22 - How Hot does it run? Tue, 14 January 2003 08:56 Go to previous messageGo to next message
I had a similar problem in my 2TG, the blades on the water pump had corroded so bad, that they resembled nails. So with the radiator cap off, the water still flowed, only slowly.
Grega
Re: TA22 - How Hot does it run? Tue, 14 January 2003 09:50 Go to previous messageGo to next message
yeah it does only flow slowly...
speaking of which was chatting with my mechanic who reckons my new thermostat might not be opening at the temp its supposed to - i'd be more on that being the cause in my case...
Redneck Rallysport
Jervis Bay
Re: TA22 - How Hot does it run? Tue, 14 January 2003 10:05 Go to previous messageGo to next message
Just cos it's a new thermostat, don't mean it runs good. A mate had a similar problem with his Suzuki GTI (rally car). Dropped a new engine in, did all the regular stuff, including new thermo, had the gauge off the dial in the first rally, first service point we took it out and threw it as far as we could. The car worked well for the rest of the rally.
Boris
Grega
Re: TA22 - How Hot does it run? Tue, 14 January 2003 21:36 Go to previous message
yep am going to swap and see how we go.
Previous Topic:RA23 Electrical Troubles!
Next Topic:Japanese translation
Current Time: Fri Nov 20 10:16:43 UTC 2026
Total time taken to generate the page: 0.0059750080108643 seconds
