Classifieds » Parts Wanted » Wtd : Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) also used in 2JZ??
nick.parker
January 2005
Wtd : Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) also used in 2JZ?? Tue, 01 November 2005 03:36 Go to next message
I want to buy a 2.9kg/cm^2 fuel pressure regulator which I beleive were only used on the smallport 16V 4AGE (90/91) (all other 4AGE regulators are 2.55) Prefer to pick one up in Perth if possible.
Cheers, Nick
[Updated on: Tue, 08 November 2005 12:11]
Scorpion
Menai area of Sydney
Re: Wanted Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) Wed, 02 November 2005 12:12 Go to previous messageGo to next message
I have a fuel rail with the pressure regulator on it but I'm not sure if it's smallport or bigport.
Do you know if there is an easy way to tell the difference ?
nick.parker
January 2005
Re: Wanted Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) Wed, 02 November 2005 13:08 Go to previous messageGo to next message
I don't know if there is a way to tell. I will look into it.
Leighp
NY
Re: Wanted Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) Wed, 02 November 2005 17:23 Go to previous messageGo to next message
i have both, i will look tomorrow, if scorp has it then talk to him first mate.
L
nick.parker
January 2005
Re: Wanted Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) Thu, 03 November 2005 10:14 Go to previous messageGo to next message
Scorpion,
Short of setting the regulator up on a fuel rail and measuring the pressure, I have no idea on how to distinguish the pressure of the regulator yet.
I have a 4AGZE (2.55kg/cm2)regulator with the number
DENSO 1240 23280 16051 on it.
I'm guessing the the 2.9kg/cm2 reg on the smallport 16v has a different part number.
LeighP can you tell us the numbers on both of your regulators please?
Regards, Nick
CLG
Perth, Western Australia
Re: Wanted Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) Thu, 03 November 2005 12:21 Go to previous messageGo to next message
I have one from a smallport motor will PM you.
nick.parker
January 2005
Re: Wanted Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) Fri, 04 November 2005 08:03 Go to previous messageGo to next message
This is the reg on my 4AGZE. If a smallport 16V regulator does not bolt up exactly the same way then I'm giving this idea a miss. My aim to to get fuel pressure increased from 2.55 to 2.9bar.
Regards, Nick
http://www.e-wire.net.au/~nrparker/ToyModsPics/DSC03868_reg_small.JPG
[Updated on: Fri, 04 November 2005 08:08]
Manny
Re: Wanted Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) Fri, 04 November 2005 08:14 Go to previous messageGo to next message
Looks identical to a 2JZGTE fuel pressure regulator in the way it mounts to the fuel rail and they are 3Bar base fuel pressure from memory.
Leighp
NY
Re: Wanted Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) Sat, 05 November 2005 17:34 Go to previous messageGo to next message
will do it sun evening after the A1GP. got em out today for you.
nick.parker
January 2005
Re: Wanted Fuel Pressure Reg from smallport 4AGE (2.9kgfcm^2 type) Tue, 08 November 2005 11:37 Go to previous message
Leighp,
Did you get a chance to get around to checking the pressure regs?
Cheers, Nick
Previous Topic:4age metal head gasket
Next Topic:RWD 4AC water pump pulley
Current Time: Wed Oct 28 17:20:05 UTC 2026
Total time taken to generate the page: 0.061164855957031 seconds
