Toymods » Tech & Conversions » F series measurement?
EVOSTi
cambo
      no
F series measurement? Tue, 01 November 2005 05:34 Go to next message
could someone please take a measurement for me? im after the length of a F series diff center, from the flange face to the mounting point of the axle housing. should be able to easily do it with the center in or out of the diff housing.
sorry if this isnt clear.
TE72_Turbo
Re: F series measurement? Tue, 01 November 2005 06:25 Go to previous messageGo to next message
This might not be of particular use to you, but from memory it was 19mm longer than a T series diff. I think I still have the comparative specs written down somewhere at home, I needed them when I converted from T to F series in my car to shorten the tailshaft by the correct amount Smile Will check.
Phil
EVOSTi
cambo
      no
Re: F series measurement? Tue, 01 November 2005 06:36 Go to previous messageGo to next message
cheers mate. i have a T series somewhere around here so if you know how much you shortened by i can compare them.
which F seriescenter and housing are you using? just incase there are different sized ones.
Lambolica
Northwestern Sydney
Re: F series measurement? Tue, 01 November 2005 06:47 Go to previous messageGo to next message
TE72_Turbo... Did you look into the possibility of another rear section of tailshaft from another car? I'll be on this as well.
Evo How close is the E rear to fitting?
EVOSTi
cambo
      no
Re: F series measurement? Tue, 01 November 2005 07:05 Go to previous messageGo to next message
havent tried yet, but my tailshaft is single piece anyway, with W59 box.
brett_celicacoupe
townsville NQLD
Re: F series measurement? Tue, 01 November 2005 12:15 Go to previous messageGo to next message
cool thread.
funnny seeing as my F series diff is about ready to go in. i got ST141 disks and MA61 LSD centre. Smile
so what are the options?
MX13 single piece (no good - too long)
MA61?
RT142?
RA6x?
MX62?
hmmm. time to take the tape measure the wreckers i think
wilbo666
Re: F series measurement? Tue, 01 November 2005 13:40 Go to previous messageGo to next message
MX62 Auto One piece shaft length 1355mm
MX73 Auto Two piece shaft length (Front = 653mm, Rear = 802mm)
SA63 Manual (W55) Two piece shaft length 1405mm (Front = )
RA65/MA61 Manual (W58) Two piece shaft length (Front = 610mm, Rear = )
RA65/MA61 Auto Two piece shaft length (Front = 530mm, Rear = )
This may help you somewhat, as you can see I didn't get around to recording some of the values...I would love to be able to add more to this list however.
TE72_Turbo
Re: F series measurement? Tue, 01 November 2005 21:12 Go to previous messageGo to next message
My F series is from an MX13 corona. I initially used a shortened T18 rear section with the T50 gearbox, then a shortened corona tailshaft (RT104?) with the W55.
I'm sorry, I can't find my notes from when I shortened the tailshaft Crying or Very Sad
Re: F series measurement? Tue, 01 November 2005 21:31 Go to previous messageGo to next message
if you PM Brett_celicacoupe on the new forums, he's just taken delivers of my ma61 diff centre, so it should be very easy for him to measure it for you (assuming he hasn't installed it yet)
brett_celicacoupe
townsville NQLD
Re: F series measurement? Wed, 02 November 2005 02:12 Go to previous messageGo to next message
draven wrote on Wed, 02 November 2005 08:31
draven,
it hasnt really got anything to do with the centre. its got to do with the distance between the tailshaft mounting flange and the flange bit where the centre carrier face meets the diff housing. also note that this is for a live axle F seires Wink
i should have pics and measurements up in an hour or so of both T and F Smile
brett_celicacoupe
townsville NQLD
Re: F series measurement? Wed, 02 November 2005 02:48 Go to previous messageGo to next message
id say im accurate to about 1mm. i only measured with a tape measure but should be okay Smile
http://img142.imageshack.us/img142/8214/diffcarrier01818dq.jpg
EVOSTi
cambo
      no
Re: F series measurement? Wed, 02 November 2005 07:51 Go to previous messageGo to next message
cheers brett. as i mentioned on the other forum, 220mm is what i measured the E series to be. so by that logic, when i later get an F series i should be able to use my tailshaft, meaning i only have to mod it once.
its not often you have a win with things like this, so im very happy Very Happy
brett_celicacoupe
townsville NQLD
Re: F series measurement? Wed, 02 November 2005 07:53 Go to previous messageGo to next message
...now i needa find a tailshaft thats ~13mm shorter Rolling Eyes Sad
EVOSTi
cambo
      no
Re: F series measurement? Wed, 02 November 2005 09:06 Go to previous message
you might have to bite the bullet and get it shortened. shouldnt be more than a coupla hundred.
[Updated on: Wed, 02 November 2005 09:07]
Previous Topic:WANTED! "AE92 GTZ" Wiring diagram
Next Topic:Strange soarer happenings
Current Time: Thu Oct 29 07:21:55 UTC 2026
Total time taken to generate the page: 0.0050981044769287 seconds
