Toymods » Tech & Conversions » 1G-GTE Engine Check Light
gold28
Madrid - Spain
1G-GTE Engine Check Light Mon, 13 January 2003 02:23 Go to next message
Can anyone help me with which pin on the computer is for the engine check light.
It is a manual Gen 2 1G-GTE if that makes a difference.
Whoever did the conversion never bothered to hook up the light. I think that the old girl is running in safe mode but can't do the diagnostic checks without the light.
Also does anyone know if the check light is supposed to be a incandescent bulb or an LED.
Hoping to get this sorted before Dyno day Evil or Very Mad
TRACTION_ISSUES
Re: 1G-GTE Engine Check Light Mon, 13 January 2003 06:25 Go to previous messageGo to next message
Call me on 0413131826....i got some wiring diagrams and should be able to help u out
CrAiGzEE
south of the big smoke
Re: 1G-GTE Engine Check Light Mon, 13 January 2003 06:42 Go to previous messageGo to next message
dude whats ya email i can email ya a diagram
ya hook into W with the other end being power
thetoyman75
Club President
icon10.gif  Re: 1G-GTE Engine Check Light Mon, 13 January 2003 15:21 Go to previous messageGo to next message
Tina's is hooked up to one of the spare Red Lights on the Dash using a spare bulb from the parts car ! (You know the bank of 5 lights in a row ! )
Works a treat now we just need to fix the Friggin Knock sensor error code that is driving me nuts !! Sad
gold28
Madrid - Spain
Re: 1G-GTE Engine Check Light Mon, 13 January 2003 20:54 Go to previous messageGo to next message
Craig - my email is <anthony.grant@ausaero.com.au> That would be great if I can get a copy of the wiring diagram off you. I have a generic Toyota wiring diagram that shows the engine check light attached to the w pin, however neither the computer or the plug show pin desciptors, so I am still not sure which pin is the w pin. Hopefully your wiring diagram can help here.
Phil - I will see how I get on with the wiring diagram from Craig, if not I will give you a call this afternoon. Thanks mate.
Rod - I was planning on doing the same thing, I have no idea why Toyota put all those annunciators in the RA28 dash, but they sure will come in handy. Was it an incandescent bulb used in the donor car? I guess it is a low voltage bulb of some sort.
Re: 1G-GTE Engine Check Light Mon, 13 January 2003 23:37 Go to previous messageGo to next message
My dash actually has a Check Engine Light, when I hook up my 1GGTE, do you think I could hook it up to this?
CrAiGzEE
Re: 1G-GTE Engine Check Light Mon, 13 January 2003 23:48 Go to previous messageGo to next message
frank that be no drama at all you will just have to find the wire that runs to the checklight or run a new one to it
gold28 ill send it to ya now
Re: 1G-GTE Engine Check Light Tue, 14 January 2003 00:07 Go to previous messageGo to next message
Woohoo, thats what I thought. Another thing I don't need to change for the 1GGTE, first mounts, then finding a new sump Razz
gold28
Madrid - Spain
Re: 1G-GTE Engine Check Light Tue, 14 January 2003 02:28 Go to previous messageGo to next message
Thanks fellas for all your help, The diagrams I got from Craig tell me exactly what I needed to know, along with a couple of other bits and pieces I was planning to figure out. I'm happier than a pig in mud.
I will wire it up tonight, all things going well.
gold28
Madrid - Spain
Re: 1G-GTE Engine Check Light Tue, 14 January 2003 20:34 Go to previous messageGo to next message
Bugger
The fantastic wiring diagram from Craig that was exactly what I needed must be from a difference version of the 1G, so I am still looking for help here.
The wiring diagram that I got off Craig shows 22, 16 and 26 pin connectors on the ECU, whereas I have 18, 10 and 24 pin connectors. At least I know now to be careful if I ever have to change computers.
The ECU has 1G-GT stamped on it instead of 1G-GTE if that means anything.
Thanks,
Anthony
thetoyman75
Club President
icon10.gif  Re: 1G-GTE Engine Check Light Tue, 14 January 2003 22:53 Go to previous messageGo to next message
Mate,
They are a small incandescent globe and it works great ! It is just the brake warning light out of the parts car Smile
gold28
Madrid - Spain
Re: 1G-GTE Engine Check Light Tue, 14 January 2003 23:04 Go to previous messageGo to next message
Thanks Rod, thats what I expected it to be. I might have a hunt around the wreckers and try and find a globe holder that will slot into the annunciator housing. Give it the factory look for anyone silly enough to want to pull the dash apart.
This might be a silly question, but on the loom diagram, it shows a warning light labeled "Turbo Indicator". I couldn't find any turbo inputs for the ECU. Any idea what it is supposed to do.
CrAiGzEE
Re: 1G-GTE Engine Check Light Tue, 14 January 2003 23:40 Go to previous messageGo to next message
the turbo indicator light is wired to a led to tell ya when ya turbos are on
the ga70 supras had them in the middle of there tachos
thetoyman75
Club President
icon10.gif  Re: 1G-GTE Engine Check Light Wed, 15 January 2003 00:02 Go to previous messageGo to next message
Mate,
That could be the Till light ! Mos has mine wired up Tina's but not sure its working right !
OK Update on error codes ! Tina's is giving error code 16 ! And accordng to the error code list Craig just sent me the Knock sensor is actually error code 52 Smile
Anyone know what the error code 16 is ???
stradlater
Arthurs Creek, Victoria
Re: 1G-GTE Engine Check Light Wed, 15 January 2003 04:12 Go to previous messageGo to next message
craig, would you be so kind as to email me those diagrams too please. Stradlater@hisplace.net
Daniel
OH, and do you know which generation the motor is?
Kman
Re: 1G-GTE Engine Check Light Wed, 15 January 2003 05:37 Go to previous messageGo to next message
Can I get the wiring diagram as well "PLEASE... " Smile
killerkace@hotmail.com
RA23_Sean
Western Sydney
Re: 1G-GTE Engine Check Light Wed, 15 January 2003 09:11 Go to previous messageGo to next message
Gold28, pull the lid off your ECU. Toyota generally label the pins as they go into the board. You'll be able to find the W wire from there if the pins are labelled.
gold28
Madrid - Spain
Re: 1G-GTE Engine Check Light Wed, 15 January 2003 20:48 Go to previous message
RA28_Sean - I thought that to, no such luck.
I spoke to Phil last night and hopefully we have it sorted now.
Thanks anyway
Previous Topic:GZE distributor
Next Topic:Malpassi
Current Time: Sun Oct 25 23:13:37 UTC 2026
Total time taken to generate the page: 0.018980026245117 seconds
