Toymods » Tech & Conversions » GZE flywheel RWD/mongrel clutch
GZE flywheel RWD/mongrel clutch Thu, 06 June 2002 12:35 Go to next message
My ae86 seems to have an incessant clutch gobbling habbit (bloody turbo...) So far I've gone through 2 daikin/exedy clutches in a coupla months, and at around $500 a pop it aint something I'm gonna throw a party about... So far I've used SKC321 and SKO321, which are supposed to be 2800lb clamping force, with the SKC one being 3 puck ceramic. Both these clutches felt great at first, but they just dont seem to last too long...
I'm using a T50 box (which so far seems to still love me) with a normal 4ag flywheel. The GZE flywheel has got a much bigger clutch area on it, which I would imagine with a decent clutch would solve my problem but for the fact that it dont fit in the bellhousing...
Does anyone know how much has got to be chewed from the housing to stuff it in? I don't want to end up taking away all the metal and having something that is going to break.
More to the point, has anyone got any other ideas? (quad plate is out of the question, unless someone can tell me next weeks winning lottery numbers...) Would be much appreciated!
mr_messy
Re: GZE flywheel RWD/mongrel clutch Thu, 06 June 2002 13:57 Go to previous messageGo to next message
your driving style might be the reason why the clutches keep dying ( Skull ) on you...
i dont know what the correct way of driving is...but that could be the reason..
Re: GZE flywheel RWD/mongrel clutch Fri, 07 June 2002 13:24 Go to previous messageGo to next message
Yes, well, driving style can ruin clutches very quickly... although I do have weak clutch in mind whenever I drive the thing - e.g. no 8000rpm sidesteps, haven't been to the drags, etc. It seems to first show trouble when the cars already rolling and I put the foot down a bit to speed up, just as it comes on boost (and therefore places a sudden gawdawful torque loading on the clutch...) Cry Twisted Evil
dorikin
NE Melbourne
Re: GZE flywheel RWD/mongrel clutch Sat, 08 June 2002 07:20 Go to previous messageGo to next message
ZE flywheel is bigger diameter right? so once you've chomped out the bell housing to fit it in, what do you then do about the starter motor?? cos if the starter motor is mounted a set distance from the crank, using a bigger diameter flywheel will mean that there will be no more starter motor, it will foul the flywheel (is this the case?????)... hehehe, never have to worry about the clutch slipping when the engine's can't start...
this is just my thoughts, i could be wrong, but to me it seems solving one problem may cause another... can anyone clear this up for me???
Re: GZE flywheel RWD/mongrel clutch Sat, 08 June 2002 11:36 Go to previous messageGo to next message
The good news is that this is not actually the case. The GZE flywheel uses the same ring gear as all the others, the difference comes from the fact that instead of having the clutch bolted on in the middle of the flywheel, it is bolted onto lumps on the outside edge giving a much greater diameter of clamping face. The problem is that these 'lumps' hit against the edge of the bellhousing, so I understand. I won't be able to know by how much until I take my gearbox out again, I was just asking beforehand so that I might be able to hear from someone thats already done this. Grin
YOGI8U
up yours!
Re: GZE flywheel RWD/mongrel clutch Sun, 09 June 2002 01:26 Go to previous messageGo to next message
its true dude!
you have to chop out the bellhousing!
if you have any questions let me know!
dorikin
NE Melbourne
Re: GZE flywheel RWD/mongrel clutch Sun, 09 June 2002 03:41 Go to previous messageGo to next message
yogi
are you still running a T50 behind your turbo 4AGE??? if so, how does it seem to cope with the power and torque of the engine???
as for the ZE flywheel inside the T50 bell housing, how much does it need to be modified to fit??? would the amount of material that is removed lead to any problems with the strength of the bell housing??? would you reccomend this for an N/A engine, or is the flywheel too heavy???
whiteGZE
Western Sydney
Re: GZE flywheel RWD/mongrel clutch Sun, 09 June 2002 04:55 Go to previous messageGo to next message
The GZE flywheel is lighter.
dorikin
NE Melbourne
Re: GZE flywheel RWD/mongrel clutch Sun, 09 June 2002 06:51 Go to previous messageGo to next message
hehehe, just after i posted my last reply, i though "i bet the ZE flywheel is lighter" of course i was not at all sure, i just figured that the advantages of a light flywheel would be the same for all engines, n/a or forced induction.
ok, so now i know this, who know what the actual weights of the flywheels are, and also, who knows how much modification is equired to fit the ZE flywheel in the T50 bell housing?
Re: GZE flywheel RWD/mongrel clutch Sun, 09 June 2002 10:54 Go to previous messageGo to next message
Yeah the ZE flywheel is a whole heap lighter, I'll weigh them up tomorrow and letcha know by how much. All I want to know is how much chopping around the housing needs in order to fit it in (pleeeez yogi?) Nod
dorikin
NE Melbourne
Re: GZE flywheel RWD/mongrel clutch Sun, 09 June 2002 12:46 Go to previous messageGo to next message
mrshin...
it sounds to me like you have a few flywheels lying around for you to weigh them up without much trouble... might that mean that the ZE flywheel is excess, and that you might be interested in selling it to me??? let me know how this sounds to you...
YOGI8U
up yours!
Re: GZE flywheel RWD/mongrel clutch Sun, 09 June 2002 12:52 Go to previous messageGo to next message
Man! i use a w58 gear box, i know everyone thinks there tuff but i beg to differ!
blew the fuck out of it at the last run at the creek!
the bellhousing is a custom dellow job!
i recevied the first or second one they did and i would have to say they are far from helpful!
we had to cut about 1/5kg out of the bellhousing, which was not the easist of jobs!
the way I did it was to put a blob of greese on to the clutch and when the greese hit a spot in the bellhousing, i grinded it out!
[Updated on: Sun, 09 June 2002 12:53]
AE86_Sprinter
Perth, WA
Re: GZE flywheel RWD/mongrel clutch Mon, 10 June 2002 00:33 Go to previous messageGo to next message
GZE flywheel may be lighter but it carries all of its weight in those big chunks of steel on the outside of the flywheel.
If you measure the rotational inertial (this is what we are actually wanting to reduce) compared to a 4A-GE one i think you might find the GE wheel is "lighter" as such. DOnt quote me, i have not meassured each of them but from looking at them, this is how it looks to me.,
Yogi, did you use the GZE wheel? maybe teh dellow housing was made for a GE flywheel? those big chunks on teh GZE wheel again can cause clearence probs.
Mike
Re: GZE flywheel RWD/mongrel clutch Mon, 10 June 2002 10:06 Go to previous messageGo to next message
I've weighed the GZE flywheel today, 6 kilos worth - bloody scales I had went off the dial when I tried to weigh the NA one!
As for rotational inertia, well I suppose I could get to work and make a whole heap of measurements, swallow a few reams of paper and work out exactly what the difference between them is - my only observation is that the supercharged engine seems to have a quicker throttle response than any of the other 4AGs (20v included), even with that nasty looking intake plumbing/manifold/throttle they have.
W58s, yeah I know they're quite breakable, all comes down to treatment really Surprised I've seen other peoples cars with them, and the resulting pile of metal they collect a few weeks later. However, I expected my t50 to self destruct, yet it still seems quite happy to be there. I'm guessing that it's probably not that much different grinding out the t50 housing compared to the dellows W5x one. Thing is, is that likely to help me using a 9" clutch over the 8" one? Theoretically I suppose it should.
Last clutch I bought I asked everyone I could find and it seems that didn't pay off. "Yeah, you won't break that one, you'll bust that box waaaay before" - but it doesn't seem to work that way. I'm thinking of using the GZE flywheel with a decent 3 puck plate, with the correct spline for the t50 (i wonder if such a thing exists...)
As for the GZE flywheel, if I don't end up using it, then yeah its for sale I guess.
Celica_RA40
Re: GZE flywheel RWD/mongrel clutch Mon, 10 June 2002 13:38 Go to previous messageGo to next message
mrshin,
you do know that you can get clutch plates custom made?
there is a place up here in brissy that does them, even though they probably wont be much good to you in melb they custom make the puck clutch plates and also make custom pressure plates and that sort of crap,
i bought a new heavy duty pressure plate throwout bearing and exedy clutch plate off them for $200 for the celica
i think a custom clutch plate is like $100 extra
Re: GZE flywheel RWD/mongrel clutch Wed, 12 June 2002 07:58 Go to previous messageGo to next message
Yah, I know that you can get clutches made to do almost anything, thing is they few places I've rung up about that kind of thing don't seem overly interested in doing a great deal for me... Whats the name/number of the one in Brissy? I'll have a talk to them.
I had a look at putting the GZE flywheel into the T50 today, and while I think with a bit of grinding, machining and shifting of the ring gear it could be done, it might be something best avoided. I suppose the dellows kit with a w58 and a decent GZE clutch would be the go. What clutch do you use yogi? Maybe some rediculously overpriced twin plate GZE clutch would keep it together, and let me get away with buying a half decent turbo/cooler in the future Grin
Rex_Kelway
Cluch for RWD 4A-GZE Wed, 12 June 2002 14:57 Go to previous messageGo to next message
Alright then what are peoples opinions on the best choice for a 4A-GZE into AE86?
1. Keep the GZE flywheel & Cluch and Machine Bellhousing.
- Availability/Cost of GZE Cluch?
- Compatibility with inputshaft and actuation fork?
2. N/A Flywheel and Clutch
- Ability to cope with torque loading?
Bear in mind that I want it to cope with potentially 200hp and be able to cope with a little vicious driving, but mostly normal.
Well?......
[Updated on: Wed, 12 June 2002 15:01]
AE86_Sprinter
Perth, WA
Re: Cluch for RWD 4A-GZE Thu, 13 June 2002 12:22 Go to previous message
well i used a NA flywheel, had it redrilled to suit a nissan silvia ( i think, i know it was nissan) pressure plate, theat pressure plate was gutted and fitted with a truck/4wd diaphram spring and it has a clamp load of 2000lb.
runnign a full face friction plate i can chirp into 4th. On a hard shift with around 200hp it still grabs REAL hard.
cost 340 for the clutch, paid 150 for origianl flywheel/clutch. Had that modded for 30% increase in clmap load but it was not real good, died after a year.
Mike
Previous Topic:5m-e Fuel Injector Upgrade Site
Next Topic:Brakes Question...
Current Time: Fri Oct 23 11:10:29 UTC 2026
Total time taken to generate the page: 0.0064380168914795 seconds
