Toymods » Tech & Conversions » MA61/RT142 suspension interchangeability
MA61/RT142 suspension interchangeability Wed, 02 November 2005 04:06 Go to next message
Does anyone know if MA61 springs/shocks will work in an RT142? I'm pretty sure the rear will be similar enough (it's an IRS model) but I'm not so sure about the front.
Corona RT142
Campbelltown
Re: MA61/RT142 suspension interchangeability Wed, 02 November 2005 04:12 Go to previous messageGo to next message
Front struts on an RT142 are the same as the RA65 pretty sure.
brett_celicacoupe
townsville NQLD
Re: MA61/RT142 suspension interchangeability Wed, 02 November 2005 06:36 Go to previous messageGo to next message
here are the king spring part no's in case u havent got them
RT142 (sedan, IRS)
front; KTFS-26
rear; KTRS-48
MA61
fr; KTFS-31
rear; KTRS-27
part no.s arent the same but ther is chance that they will fit regardless. i guess you will need first hand experience of someone actually using the said bits.
Stefan
Hobart, Tas
Re: MA61/RT142 suspension interchangeability Wed, 02 November 2005 07:48 Go to previous messageGo to next message
I'm guessing that front MA61 springs will raise the front of an Rt142, as I have read that this is what happens if Ma61 springs are put into an xA6x celica. Makes sense; much heavier engine.
GTtwin
Newcastle, Australia
August 2005
Re: MA61/RT142 suspension interchangeability Wed, 02 November 2005 08:05 Go to previous messageGo to next message
I know for a fact that front struts are exactly the same height in an ST141/RT142 as an MX73. The top and bottom mounts are different, so they wont bolt in. The RT142 rear end appears identical to an MX73, so MX73 ventilated rotors and bigger callipers will bolt straight on. I know none of this refers to MA61, but an MA61 is simply a cressida in a skirt if I'm not mistaken.
Razz
[Updated on: Mon, 07 November 2005 01:14]
wilbo666
Re: MA61/RT142 suspension interchangeability Wed, 02 November 2005 10:03 Go to previous messageGo to next message
I suspect the front will work, but you will need the MA61 top spring hat, as MA61 springs have a larger dia at the top...
GTtwin
August 2005
Re: MA61/RT142 suspension interchangeability Wed, 02 November 2005 12:22 Go to previous messageGo to next message
The diameter on those two are identical, the only problem being the ST141 tops are flat, while the MX73 are slightly curved so the holes dont line up. Also the spring rates and lengths seemed identical, which seems strange. You would think the heavier 5M would have stiffer springs.
chubbylover53
Re: MA61/RT142 suspension interchangeability Thu, 03 November 2005 07:17 Go to previous messageGo to next message
i know for a fact that the rear of the MA61 will fit into an RT142 as that's wat i put in my car after a lovely spin into a gutter one wet night. As for the fronts i was under the impression that they were longer but then with all the info around these days who knows wat to believe.
cheers mike,
GTtwin
August 2005
Re: MA61/RT142 suspension interchangeability Thu, 03 November 2005 07:29 Go to previous messageGo to next message
Did that picture work guys?
Re: MA61/RT142 suspension interchangeability Thu, 03 November 2005 09:12 Go to previous messageGo to next message
No. You can't link to pictures on your hard drive, they need to be hosted somewhere.
wilbo666
Re: MA61/RT142 suspension interchangeability Thu, 03 November 2005 13:39 Go to previous messageGo to next message
Jemery, charles says RT142's have different caliper bolt spacing as well compared to MA61 struts! Not sure if you knew that...
(is not 100m as R33 calipers...)...
Re: MA61/RT142 suspension interchangeability Thu, 03 November 2005 13:43 Go to previous messageGo to next message
is a shame no having the right caliper mounts
my photoshop work suggest the stub axle on the RT142 is 2.5 degrees better than the MA61
http://static.flickr.com/25/58541690_bc1341c1f2_o.jpg
Re: MA61/RT142 suspension interchangeability Fri, 04 November 2005 01:31 Go to previous messageGo to next message
Nah I'm not attempting to put RT142 bits in an MA61. An RT142 owner is interested in buying my old springs/shocks and I want to know if they'll fit before I sell them to him.
GTtwin
August 2005
Re: MA61/RT142 suspension interchangeability Mon, 07 November 2005 01:11 Go to previous messageGo to next message
Alright, its going to work this time!
http://www.importperfection.com.au/Struts.JPG
Corona left Cressida right
[Updated on: Mon, 07 November 2005 01:12]
cambelt
melb
Re: MA61/RT142 suspension interchangeability Mon, 07 November 2005 13:02 Go to previous message
The trailing arms fit but the whole subframe out of a mx73 wont fit a ma 61 , as the 73 is about 60 mm wider
Previous Topic:3tgte ecu for 2tgte and knock control Q
Next Topic:SETup for 4AGZE / W55 Gbox into AE86 ??
Current Time: Thu Oct 22 06:57:02 UTC 2026
Total time taken to generate the page: 0.0058939456939697 seconds
