Toymods » Tech & Conversions » 3sgte gen1 - gen2 crank differences?
gemtoy
melb
3sgte gen1 - gen2 crank differences? Wed, 02 November 2005 06:02 Go to next message
Hi All,
Does anyone know if the cranks on a gen1 3sgte are stonger or weaker than a gen2 3sgte ? I have been seaching over the weekend without much success.
I was thinking of starting a thread about the 3sge engines and try to show which parts are compatable between different generations. Is this a good idea ?
Paul
RWDboy
Re: 3sgte gen1 - gen2 crank differences? Wed, 02 November 2005 14:00 Go to previous messageGo to next message
Sort of Wink
I will let you know the exact differences between the two cranks when i blue-print my ST165's engine. The only difference I can see at this point is the oil-ways are slightly larger on the gen 2 crank.
gemtoy
melb
Re: 3sgte gen1 - gen2 crank differences? Thu, 03 November 2005 11:54 Go to previous messageGo to next message
Does anyone know ?
TA22-3SGTE
MACKAY
Re: 3sgte gen1 - gen2 crank differences? Thu, 03 November 2005 20:29 Go to previous messageGo to next message
The gen 2 also uses larger flywheel bolts so the flywheels are not interchangeable , I have put over 400 hp out of the gen 1 with standard internals witout problems other than headgaskets .
Trevor
RWDboy
Re: 3sgte gen1 - gen2 crank differences? Thu, 03 November 2005 22:46 Go to previous messageGo to next message
What he said.
I think the flywheel is different size as the starter motor is in a different spot on most gen 2 engines.
gemtoy
melb
Re: 3sgte gen1 - gen2 crank differences? Fri, 04 November 2005 10:02 Go to previous messageGo to next message
I just picked up a gen1 3sgte and have stipped it for some parts and to have a look.
I puchased last year a gen2 3sgte crank (I hope it is, this is what I was told Mad )and it has the same bolt sizes as the gen 1
both are 10 x 1.25mm holes 8 of them.
the gen3 crank I have is also 8 bolt but is 12 x 1.50mm
What is the torque spec for the 10mm bolt crank ?
RWDboy
Re: 3sgte gen1 - gen2 crank differences? Fri, 04 November 2005 23:57 Go to previous messageGo to next message
Have a look at the oil-ways if you aren't sure whether it's a gen 2 crank or not...
gemtoy
melb
Re: 3sgte gen1 - gen2 crank differences? Sat, 05 November 2005 05:48 Go to previous messageGo to next message
What am I looking for regarding the oilways ?
RWDboy
Re: 3sgte gen1 - gen2 crank differences? Sun, 06 November 2005 05:16 Go to previous messageGo to next message
I'm pretty sure the oil feed for the main or big-end bearings is larger on the gen 2 crank than the gen 1.
rokusan
western queensland
Re: 3sgte gen1 - gen2 crank differences? Sun, 06 November 2005 06:20 Go to previous message
i have both here, the gen1 is slightly lighter this may mean weaker? also the gen1 has a smaller diameter rear main so requires a different seal,
Previous Topic:3sg flywheel bolts
Next Topic:Carby Engine-Port&Polish is it worth the trouble ?
Current Time: Sun Oct 25 08:05:25 UTC 2026
Total time taken to generate the page: 0.0052030086517334 seconds
