Toymods » Tech & Conversions » Sealant required on 2t-g head gasket
hemi twofifteen turbo
Sealant required on 2t-g head gasket Wed, 02 November 2005 09:44 Go to next message
I have the following 2t-g head gasket, the toyota manual says to use sealant on it, although modern gaskets u usually dont. (ones with build in sealant rings etc, although this one has none. It appaears to be graphite, and from what i've heard u dont use sealany on graphite gaskets, can someone fill me in? Here is a pic of the gasket:
http://img23.imagevenue.com/loc16/th_fe6_DSC01418.JPG
Re: Sealant required on 2t-g head gasket Fri, 04 November 2005 07:00 Go to previous messageGo to next message
Has anyone assembled a 2t-g recently? May even be the same as a plain 2T? I'm 90% sure i don't use sealant due to being 90% sure it's a graphite gasket, but please can someone make me 100% before I do it! Thanks!
earlyrolla
Re: Sealant required on 2t-g head gasket Fri, 04 November 2005 15:55 Go to previous messageGo to next message
I would use Hylomar on the gasket. I have used this a few times on both my engine and other peoples engines that I have worked on. Put simply, it is good s*&t! The spray on stuff is easier to apply.
I am guessing the Toyota manual would only recommend the use of sealant around the joining between the timing cover and the engine block, this is because of the potential uneveness of this region.
Once again, I would use a smear (note smear, not a whole tube!) around the entire timing cover top lip that touches the head gasket. You might need a slighlty bigger dob around the timing cover/engine join.
wombat
Laverton, Vic
Re: Sealant required on 2t-g head gasket Tue, 08 November 2005 05:29 Go to previous message
the last three 2tgs I built and rebuilt in the last 2 months I didn't put any sealer on the head gasket. I only every put a thin layer of grease on the block, and on the head, then wack the gasket on and off she goes. that said I do use a sealent on all the paper type gaskets, eg. water pump, timing case, thermostate housing, and some times the sump, depends if it's cork or a rubber one.
Never had any problems, and also if you need to take the head off againg it makes the gasket 100 times easier to take off.
Previous Topic:1jz prob help****
Next Topic:3sgte cambelt timing marks?
Current Time: Sat Oct 17 01:30:59 UTC 2026
Total time taken to generate the page: 0.022962808609009 seconds
