Toymods » Tech & Conversions » Supra CT26 vs GT4 CT26
TE72_Turbo
Supra CT26 vs GT4 CT26 Mon, 13 January 2003 07:23 Go to next message
OK, so the Supra CT26 is single entry, and the MR2/GT4 is twin entry, but can you interchange the two?? I want to fit a twin entry exhust housing to a supra core & compressor.
can it be done??
thanks in advance
wastegate
Gold Coast
Re: Supra CT26 vs GT4 CT26 Mon, 13 January 2003 08:26 Go to previous messageGo to next message
You will have to machine out the inside of the GT4 Turbine housing due to the GT4 Turbine being slightly smaller.
TE72_Turbo
Re: Supra CT26 vs GT4 CT26 Mon, 13 January 2003 10:10 Go to previous messageGo to next message
are you sure?? I was under the impression that they had the same turbine specs, just one was ceramic...
I'm not saying you're wrong, It would just help my case if you were Smile
E30-323ti
Re: Supra CT26 vs GT4 CT26 Mon, 13 January 2003 20:07 Go to previous messageGo to next message
You may find the Supra turbine wheel has a different trim height etc... and the housing will need to be machined. This isn't a biggie, most turbo shops shouldn't charge more than hours labour to do this, If you handy with a lathe you could do it yourself.
I'm sure someone could help you out with the tolerances.
TE72_Turbo
Re: Supra CT26 vs GT4 CT26 Mon, 13 January 2003 21:47 Go to previous messageGo to next message
what motor is that in your E30??
E30-323ti
Re: Supra CT26 vs GT4 CT26 Tue, 14 January 2003 23:44 Go to previous messageGo to next message
1JZ-GTE
All bolted in, now battling the wiring!!!
[Updated on: Tue, 14 January 2003 23:56]
TE72_Turbo
Re: Supra CT26 vs GT4 CT26 Thu, 16 January 2003 12:43 Go to previous messageGo to next message
The CT26 exhaust housings are interchangeable .
I swapped them today. Smile
**BETSY**
uk england
April 2005
Re: Supra CT26 vs GT4 CT26 Wed, 13 April 2005 19:28 Go to previous messageGo to next message
just to confirm, you fitted a st 185 ct 26 twin entry turbine housing to your supra ct 26 single entry compressor and centre core?
Joshstix
Toymods Vice President
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 04:47 Go to previous messageGo to next message
We did this for Dave the events co-ordinator. We put a 7M CT26 turbo into his ST185 exhaust housing.
One question though, why did you want to use the twin entry turbine housing?
**BETSY**
uk england
April 2005
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 06:59 Go to previous messageGo to next message
i am using a gen 1 3sgte engine at the moment which of cousre uses the single entry turbo.
i have bought a supra ct26 and when i finish building my new gen 2 3sgte shall be going with the twin entry set-up to enable me to use the st 205 charge cooler etc
[Updated on: Thu, 14 April 2005 07:00]
Joshstix
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 08:37 Go to previous messageGo to next message
**BETSY** wrote on Thu, 14 April 2005 16:59
OK off topic but, you know you'll have to modify the inlet on the ST205 cooler and the outlet doesn't go into the St185 rubber throttle body neck right.
The 205 has the turbo further towards the gearbox so the IC doesn't line up if you use a Gen2 exhaust manifold and a Gen3 exhaust manifold doesn't fit a Gen2 head.
davedave
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 08:46 Go to previous messageGo to next message
I was scratching my head for a little while wondering why people had been able to clock the ct26's on gen2's and I had no chance of clocking the ct20B on my gen2 as it would foul on the starter buldge.
**BETSY**
uk england
April 2005
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 11:17 Go to previous messageGo to next message
hi, the st 165 has been fitted with a st 205 charge cooler over in the states, saved 1992.
im aware the t/b inlet is 55mm as oppose to 60mm ( 70mm on charge cooler outlet)
all fun and games Smile
TE72_Turbo
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 12:18 Go to previous messageGo to next message
Wow Shocked this is old!
I swapped the housings cause boost response on my old 4AGE turbo setup was crap, and was trying to improve it with the [supposedly smaller A/R] twin entry housing.
**BETSY**
uk england
April 2005
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 12:34 Go to previous messageGo to next message
and did it improve response?
i guess not!?
TE72_Turbo
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 12:39 Go to previous messageGo to next message
Only by about 200-300rpm, cause I didn't have a twin entry manifold to match. I just ported the divider between the two ports in the exhaust housing to remove the flow restriction of the flat surface.
I knew it was a gamble for possibly no return, but had both housings so figured it was worth a try, for research if nothing else!
Phil
**BETSY**
uk england
April 2005
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 12:41 Go to previous messageGo to next message
cheers for shring this with us phil.
its what the net needs, definate answers as opposed perhaps and maybes..
Smile
TE72_Turbo
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 12:46 Go to previous messageGo to next message
No worries.
So you don't wan't me to tell you that it was actually my mate's dad's stepcousin who knew someone who raced once that had a dog that reckoned it should make an extra 5psi & 55kw? Laughing Razz Razz Just kidding. Sorry to all of the third-hand information givers out there Smile I didn't mean to hurt any feelings.... much
**BETSY**
uk england
April 2005
Re: Supra CT26 vs GT4 CT26 Thu, 14 April 2005 16:36 Go to previous message
i like ya sense of humour but... you stole my yarn of my mates dads friend down the pub said his brothers neighbour who's brother twice removed..........
lol... cheers buddy...
Previous Topic:After a cheap good quality amp
Next Topic:How to modify petrol tank?
Current Time: Tue Oct 13 18:05:50 UTC 2026
Total time taken to generate the page: 0.054122924804688 seconds
