Toymods » Tech & Conversions » 1JZ / 7M Starter motor compatibility
teejay
perth
1JZ / 7M Starter motor compatibility Thu, 03 November 2005 06:01 Go to next message
Ive got a 1jz cressida which has just managed to kill either the fuel pump or ignitor. As it died in a very dangerous spot I used the age old trick or cranking it in gear to get it off the road... in turn im pretty sure killing the starter motor.
Simple question, can you use a 7m or even say a 1G one in its place? I happen to have have easy access to both of those over a 1J one..
Car in question is 1JZ GTE R154 manual cressida.
TJ
ed_ma61
Lost in the K hole
Re: 1JZ / 7M Starter motor compatibility Thu, 03 November 2005 06:07 Go to previous messageGo to next message
7m = very yes
teejay
perth
Re: 1JZ / 7M Starter motor compatibility Thu, 03 November 2005 06:11 Go to previous messageGo to next message
Auto or manual any issue ?
Re: 1JZ / 7M Starter motor compatibility Thu, 03 November 2005 09:13 Go to previous messageGo to next message
Presuming you're talking about the smaller, backgeared one, then you can swap a variety of starters in place of it. I did this yesterday with a 4A(F?) starter, just swapped the cast piece off the front of the 1JZ one onto it, and all was well. Find a Toyota starter that appears to be the same size etc. and you should be able to piece one together.
wilbo666
Re: 1JZ / 7M Starter motor compatibility Thu, 03 November 2005 13:40 Go to previous messageGo to next message
http://everest.fit.qut.edu.au/~n4150414/JZA61/1JZ-GTE/tn_DSC01353.JPG
5M on left, 1JZ on right.
Both bolt up/fit to a 1JZ (auto or manual should not make a difference).
terra
July 2005
Re: 1JZ / 7M Starter motor compatibility Thu, 03 November 2005 16:34 Go to previous messageGo to next message
BLING BLING!
joorsh
Re: 1JZ / 7M Starter motor compatibility Fri, 04 November 2005 00:09 Go to previous message
The bolt pattern between the 1j/2j & 7M starter motor is the same, however I ran into problems when I tried to use a 7M starter motor on a 2J. It wasn't clearing the ring gear when it was fully disengaged. Neither the ring gear nor the flywheel were standard on my car, so this undoubtably contributed to the problems - just be aware that they are not identical, so if you start swapping in aftermarket parts (like flywheels) you may run into problems with the 7M starter.
The 2J starter motor is also supposed to be a pretty common upgrade for 7M owners, so it wouldn't make much sense to go backwards (if you can avoid/afford it).
[Updated on: Fri, 04 November 2005 00:12]
Previous Topic:Needed EPC Part Code for ST184 / 5SFE
Next Topic:AE86 Swaybars
Current Time: Tue Oct 20 15:53:17 UTC 2026
Total time taken to generate the page: 0.0083730220794678 seconds
