Toymods » Tech & Conversions » T series crossmember dimensions
jesseT18
Castle Hill, Sydney
T series crossmember dimensions Thu, 03 November 2005 06:33 Go to next message
hey guys
i converted a T series xmember to rack and pinion and crashed the car and im just trying to figure out of crossmember is still straight.
does anybody else have a TE7x/KE70/AExx series crossemember lying around they could measure up for me.
i measured mine and it measured
front bolt holes 760mm apart from eachother, centre to centre
rear bolt holes 790mm apart
thanks, jesse
Grega
melbourne.victoria.austra...
Re: T series crossmember dimensions Thu, 03 November 2005 08:40 Go to previous messageGo to next message
try here
http://www.geocities.com/jonnyr_1973/2tswap.html
Purple_Beasty
New Zealand
Re: T series crossmember dimensions Fri, 04 November 2005 04:08 Go to previous message
NAMDAMAMI wrote on Sat, 04 June 2005 04:04
Cross-member measurements as follows:
Transverse distance between rear chassis leg bolt holes =
AE86 760mm / TA22 705mm (27.5mm out either side)
Transverse distance between front chassis leg bolt holes =
AE86 775mm / TA22 726.6 (24.3mm out either side)
Longitudinal distance between front & rear holes =
AE86 140mm / TA22 114mm (13mm out)
Note that TA22 measurments taken from Toyota repair manual, AE86 measurments taken by me with tape (so approximate).
Found that in another post, too hard to measure mine accurately with the engine in.
Callum
Previous Topic:RA23 Intercooler
Next Topic:air con not engaging
Current Time: Fri Oct 23 02:05:56 UTC 2026
Total time taken to generate the page: 0.012184858322144 seconds
