Toymods » Tech & Conversions » can unleaded be used with a 4ac sprinter
Cj_sullivan
melbourne (Western Suburb...
April 2005
can unleaded be used with a 4ac sprinter Fri, 04 November 2005 11:45 Go to next message
just wanting to know , if i can run my 4ac sprinter on unleaded , or do i have to use the additive , i know this is a lame question to ask , but need car running properly to get registered ,
cheers Corie
xolent
Re: can unleaded be used with a 4ac sprinter Fri, 04 November 2005 11:49 Go to previous messageGo to next message
you can use unleaded
c2888
Re: can unleaded be used with a 4ac sprinter Fri, 04 November 2005 12:46 Go to previous messageGo to next message
You can run unleaded, toyotas have had hardened vavle seats long before 1986.
choose your own adventure
1. PULP 95 octane, no adjustments. EDIT Standard timing 5° at 900 rpm
2. ULP 92 octane, need to retard timing, i can't remember correctly, but it may be 5 degrees. EDIT Modified timing 0° at 900 rpm
1. You drive off happy into the sunset with full power.
2. You lose all of diddly squat and are still happy because it's a LASRE 4A!!!
EDIT:
here's the info Very Happy
http://www.aip.com.au/health/lead_guide.htm#Toyota
dan
[Updated on: Fri, 04 November 2005 12:54]
Cj_sullivan
April 2005
Re: can unleaded be used with a 4ac sprinter Fri, 04 November 2005 12:49 Go to previous messageGo to next message
yea coz my car is pingin , and blowing a bit of black smoke , so just unleaded in it , and retard the timing , and it'll go away
Re: can unleaded be used with a 4ac sprinter Fri, 04 November 2005 13:35 Go to previous messageGo to next message
You can probably just about run a 4AC on power kero Razz Razz Razz
(kidding)
TRD_07
September 2005
Re: can unleaded be used with a 4ac sprinter Fri, 04 November 2005 13:36 Go to previous messageGo to next message
unless you have an engine that's different to the one supposed to be in the sprinter i.e. a version of the 4A-C from somewhere else i dun see why it should be pinging.
you can run it with up to 15 degrees timing at just 91 octane. If it pings at high revs the engine is tired.
Just put 91 and make sure it's tuned correctly i.e. 5 degrees at 900 RPM (850 if it's not dying is fine), and set the fuel mixture on the carbie. check the carbie is good i.e. flow and float, change stem seals if you have to and it should be good.
My mate had to clean out his carbie coz the petrol in it b4 was shocking, clogged up a fair bit of the fuel inlet.
Ko Ko
Re: can unleaded be used with a 4ac sprinter Fri, 04 November 2005 13:59 Go to previous message
I was in the same situation as you before. I placed normal unleaded in the 4ac although it didnt run too well. I suggest you use premium petrol with the valve saver/leaded substitute. But I never knew the engine had hardened seals.
Previous Topic:3TGTE wiring issues
Next Topic:getting tapedeck out
Current Time: Sun Oct 18 11:53:53 UTC 2026
Total time taken to generate the page: 0.0058798789978027 seconds
