Toymods » Tech & Conversions » 4AGE coil?
Phrostbyte
Frankston, Victoria
4AGE coil? Sat, 05 November 2005 09:01 Go to next message
Hey there peeps,
Heard many different people say to use resisted coil or not etc. Can people please just go out to your 4AG powered car and see what ignition coil you use?
Kev.
Phrostbyte
Frankston, Victoria
Re: 4AGE coil? Sat, 05 November 2005 13:34 Go to previous messageGo to next message
bump... Please someone help?
TRD_07
September 2005
Re: 4AGE coil? Sat, 05 November 2005 13:46 Go to previous messageGo to next message
4A-C uses a coil with resistor
4A-GE (Bigport with TVI-S) doesn't use a resistor (and nothing's blown in my experiment yet so i guess it's not meant to have one)meaning i'm not sure but mine doesn't have one.
4A-GZE definitely doesn't come with one.
some people say it's not necessary but don't listen to them. better to have it and be safe then know it's not needed, then not to have it at all and burn the dizzy..
TRD_07
September 2005
Re: 4AGE coil? Sat, 05 November 2005 13:50 Go to previous messageGo to next message
FYI
resistor is a white little box typically sit on top of the coil (on the coil's bracket)
one wire from +ve of coil goes into resistor, the other is from earth -ve.
what i gather is it controls the current that gets to the dizzy so it doesn't blow out the dizzy's assembly.
me bigport didn't come with it, has standard bracket for coil.
hope that helps cheers
Phrostbyte
Frankston, Victoria
Re: 4AGE coil? Sat, 05 November 2005 21:09 Go to previous messageGo to next message
I was told by a friend last night that the resistors had an input of 12V and output of 6V, and were used only on point style engines like the 4KC and 4AC.
Kev.
TRD_07
September 2005
Re: 4AGE coil? Sun, 06 November 2005 03:32 Go to previous messageGo to next message
and so saying that, i've checked another mate's 4A-GE doesnt have a resistor.
that sounds about right, 12V in 6V out. makes the same big spark on all 4 plugs though...
Phrostbyte
Frankston, Victoria
Re: 4AGE coil ignition bosch spark Sun, 06 November 2005 05:21 Go to previous messageGo to next message
For future reference
Bosch SU12 (Standard Version)
Bosch GT40 (Sports Version)
There is a big price difference between them too, I myself just went for the standard, as it should easily be enough, but those with extra compression or GZE/GTE should probably go for the GT40 for a stronger spark.
Kev.
TRD_07
September 2005
Re: 4AGE coil? Sun, 06 November 2005 05:42 Go to previous messageGo to next message
the 4A-C has a dirty fuel problem so the lines are a bit clogged...
i had to change the coil and went for the GT40 without the resistor so just used the old one.. and straight away you could tell the difference.. it runs a lot better and accelerates smoother. not sure if the spark is better but i put it down to having a new coil. it's just 30 bucks for me anyway..
will clean the fuel line soon.
Re: 4AGE coil? Sun, 06 November 2005 08:21 Go to previous message
GT40 = teh ultimate in budget bogan coils Razz
Any point ignition system is CRAP, plain and simple, no exceptions. Resistors are only used in point systems to act as a current limit to avoid frying the coil and the points, because the points have no ability to control the dwell time accurately (it varies with engine speed)
Just use the standard 4AG igniter/coil unit, will do the job just fine.
Previous Topic:traction difference??
Next Topic:weird blinker problem
Current Time: Thu Oct 29 12:57:03 UTC 2026
Total time taken to generate the page: 0.0089590549468994 seconds
