Toymods » Tech & Conversions » wft does a pintle cap do?
ed_ma61
Lost in the K hole
wft does a pintle cap do? Thu, 06 June 2002 12:56 Go to next message
i give up!!
have been playing with these bloody injectors, and i think i'm over it! aligning the pintle cap to be perfectly aligned on the injector tip (exactly over the pintle) is damn near impossible, and im afraid it going to wreck the spray pattern...
from what i can see, the cap does nothing for spray quality normally, so WHAT do they do??
thermal insulation?
reduce carbon buildup?
wtf?
aggghhhhhh!!!!
ed
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Thu, 06 June 2002 13:36 Go to previous messageGo to next message
nevermind:
fyi
" The plastic hats are only there to protect the pintle ends and don't play much part in the spray pattern on the stock injectors. A cracked one just looks bad"
cool, gratuitous post # increase
ed
Re: wft does a pintle cap do? Thu, 06 June 2002 22:56 Go to previous messageGo to next message
Skanky post ho! No No No
wilbo666
Re: wft does a pintle cap do? Thu, 06 June 2002 23:51 Go to previous messageGo to next message
Look whos talking GT!
lol
Re: wft does a pintle cap do? Fri, 07 June 2002 00:34 Go to previous messageGo to next message
Guilty as charged! Grin
Re: wft does a pintle cap do? Fri, 07 June 2002 00:35 Go to previous messageGo to next message
God, there you go again. You still playing with injectors ey ed?
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Fri, 07 June 2002 01:07 Go to previous messageGo to next message
hey, stop taking advantage of my post for personal gain!
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Fri, 07 June 2002 01:10 Go to previous messageGo to next message
and i guess this means no-one knows shit about pintle caps?!
jcmf...yep, still playing, but sorted it out last night.
gt...got it sorted. will still use the manifold i cleaned yesterday as the 3mm of metal removed from the inside is totally inconsequential. infact, might be good to reduce heat soak of the injectors.
jcmf... how on earth did your post count get THAT big??
ed
Re: wft does a pintle cap do? Fri, 07 June 2002 01:28 Go to previous messageGo to next message
Ed...to tell you the truth...I dont know. I have an opinion on everything, and I kind of absorb something once I've read it. If you look through my posts, theres not really any whoring, I just read every post and try to help out where I can.
Re: wft does a pintle cap do? Fri, 07 June 2002 01:57 Go to previous messageGo to next message
Excellent. Do you reckon you'll have it ready for your trip to Melb? Bolt it straight up to the 5MTE! Did you get the little grommets from Toyota? Surprised
I'll ring Ridgecrest today about a copper head gasket for the thing and measure the comp ratio tomorrow.....I have been flat out.
Cheers Dave.
Argh...stupid work computer! What thickness were you after?
[Updated on: Fri, 07 June 2002 02:00]
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Fri, 07 June 2002 03:41 Go to previous messageGo to next message
haha... forgot about the gromets! will ring in a min (persoanly, i like my fuel hose idea)
h/g.. like i said, depends on the comp/r at the moment, but at a guess, with 12psi in the back of my mind, im thinking 1.00-1.20mm?
ill probably send the manifold down rather than bring it. that way you can have some time up your sleeve to fit it.
have to retest the inj spray ttomorrow (might have buggered one last night), and check the consistency of flow rate b/w injectors... might have to go hunting for some spares to make up a 5% matched set.
ed
Re: wft does a pintle cap do? Fri, 07 June 2002 04:51 Go to previous messageGo to next message
1mm 95 + freight
2mm 150 + freight
Will check comp ratio tomorrow. I'll also have to check and see if they recommend the head needs to be machined to suit.
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Fri, 07 June 2002 05:32 Go to previous messageGo to next message
goddamn, thats cheap!
head machined? just resurfaced... or are we talking o-ringing?
what are you thoughts on final comp/r at say 10-12psi boost? i remember reading somewhere a max of 11.8 was sustainable for an NA 5m stock.
with a new h/g and a hairdrier, i'm not sure what the target should be.
not yet anyway... let the reading commence
ed
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Fri, 07 June 2002 06:04 Go to previous messageGo to next message
o-mi-god
you know how i jokingly said $7 each for those grommets.... try $6.50 each.. really... Freak
Arrow hello 0.75" fuel hose!
ed
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Fri, 07 June 2002 06:06 Go to previous messageGo to next message
and the o-rings... little 7mm dia jobbies, try "wont get much change outta $4 each mate"
glad i lifted those ones from the wrecker when i did
Re: wft does a pintle cap do? Fri, 07 June 2002 06:15 Go to previous messageGo to next message
There is also a wider range but being a pretty basic guy I just went for the basic thicknesses. By machining, I meant a surfacing that was appropriate for a copper head gasket, as opposed to O-ringing.
I reckon 10 psi with a bigger blower and thick head gasket and take it from there!
Wow! Nasty nasty price for less rubber than a condom! And way less fun!
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Fri, 07 June 2002 06:41 Go to previous messageGo to next message
not sure abut comp/r.. feel like im pissing in the wind with this one... though with the right plugs, 98RON fuel (lots of it) and a carbon free engine...
say at 12psi we aim for a final comp/r of between 13.5 and 14.5??
that means aiming for an initail comp/r of 7.5 - 8.0.
im thinking any lower and its going to be a SLUG off boost.
sooo... h/g thinckness comes down to what current comp/r is really.
what did you say retard was at peak boost? 15 deg??
ed
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Fri, 07 June 2002 07:08 Go to previous messageGo to next message
and then theres the idea that its made to run at 6psi. so start off with comp/r of like 8, and happily run 6psi with and ECR of 11-12, then when the day comes for the t3/4 and 12psi, implement the methanol injection, and that will take care of the 14+ ECR at boost.
blagh... where do you reckon this thing is gong to start detonating? im thinking a ECR around 11.5 ish. theres no point retarding the timing too much to compensate, it just becomes wasteful.
ed
Re: wft does a pintle cap do? Fri, 07 June 2002 08:16 Go to previous messageGo to next message
Um, do you remember when you first asked, all you wanted was a simple 5M with a turbo that would run a comfortable 6 psi and be reasonably tractable on the street?
Now it's a low comp T3/4 hybrid running 12 psi and methanol injection! hehehe
Re: wft does a pintle cap do? Fri, 07 June 2002 09:11 Go to previous messageGo to next message
Yeah...its nothing compared to me though.
Look at my list of things I wanted/want to do:
1GGTE --> RA60 Celica
1GGTE --> Mk2 Supra
1JZGTE --> Mk2 Supra
1UZFE --> Mk2 Supra
1UZFE w/ individual throttle bodies --> Mk2 Supra
(I'd still like to do these, either with/without ITB's)
3UZFE w/ ITB's --> SZ-R Mk4 Supra
I still reckon it sounds like a nice list Smile
[Updated on: Fri, 07 June 2002 09:12]
Re: wft does a pintle cap do? Fri, 07 June 2002 10:39 Go to previous messageGo to next message
Maybe you should re-post that because the forums must have died on you again!
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Fri, 07 June 2002 10:45 Go to previous messageGo to next message
gt... "when in rome"
no, really, its more a case of maximising whats there whilst taking into account the effort/cost/reward ratio... keep it simple. take care of the small things at the start, and the big things will look after themselves later.
if a t3/4 with methanol injection is feasable in the longrun given a little forethought early, i say 'why not' Rolling
later
ed
but yes, youre right... humble beginnings...
Re: wft does a pintle cap do? Fri, 07 June 2002 10:54 Go to previous messageGo to next message
Razz
Nah....they're all easy things to do, particularly whilst the engine is on the stand. And relatively good value for money.
ed_ma61
Lost in the K hole
Re: wft does a pintle cap do? Fri, 07 June 2002 13:41 Go to previous message
shite,
injector no. 1 has a terminal spray problem... only *just* but there are definietly some heavier droplets in its spray...bugger No No No
off to the wreckers tomorrow, find another 1 280 150 215/216...
and GT... btw, i dont plan to run 12psi, just using that as the overenginerring threshold... would be more than happy pushing 10psi through, having spooled at 2.8-3.2k, peaking 3.5-4k.
but thats some ways off now isnt it....
ed
Previous Topic:Hubs for a 3SGTE
Next Topic:KE70 4KC
Current Time: Tue Oct 20 15:53:52 UTC 2026
Total time taken to generate the page: 0.0065498352050781 seconds
