Toymods » General Car Talk » Large Wheel & Rim - Safety VS LooKing Nice
osix
Singapore
October 2005
Large Wheel & Rim - Safety VS LooKing Nice Sat, 05 November 2005 22:21 Go to next message
My Ta22 Had been converted to REAR Disc brake .- but the brake look SMALL
notthing compare to what i saw on my father car (Benz)
is it easy to have a LARGe DISC Brake ?
MY RIm . is 15 " 195/50/15
I am Hoping to Install a A large RIM and Wheel
Here are what i THINK
205/55/16
205/50/16
205/45/16
Can i got for 215 /50 /16 will my Ta22 be able to fit such wheel and rim ?
is it SAFE to have The larger Wheel .
What is the a Normal REAR DISC brake limit ?
If my Front Tire and Rear Tire is Diffrent .
how should i arrange it .?
should 195 be infront or 205 should be infront ?
Show us yor Wheel and Rim Smile
someone offering me a SEt of 16 Inches Rim for $250 USd
With tire .
so i was hoping to Fit it on my TA22
Comment freely Smile
OSIX
Re: Large Wheel & Rim - Safety VS LooKing Nice Sat, 05 November 2005 22:53 Go to previous messageGo to next message
OK. There are a few issues here.
Yes you can fit 16" wheels to your TA22. You will need to obtain wheels of the correct PCD (114.3 x 4) and offset so that you don't have issues with the tyres rubbing on the guards. The boys that have done this here should hopefully step up to the plate.
As for tyre width, that is dependent upon the width of your wheel. You need to give us that information.
Personally, I would leave the rear discs alone. It is unlikely that your stock 1GFE will outstrip the braking performance of your car. Most of your braking is done by the fronts anyway and my preference would be to upgrade the fronts. Because it is a backyard conversion (and so your brakes could be doing anything), in the future you may wish to take your car to a specialist brake centre where the front and rear line pressures could be measured.
osix
Singapore
October 2005
Re: Large Wheel & Rim - Safety VS LooKing Nice Sat, 05 November 2005 23:27 Go to previous message
I had sem Maybe Disc Brake here -
From Skyline to truck larger Disc brake - What Kinda Disc Brake can be Fitted for the TA22 ?
let say i want a Upgrade -
What kinda Disc brake Fit the FRONT ?
and what kinda disc Brake Fit the REAR ?
what is PCD ?
Even my Suspension and shock up is MESSy up ..
The RIght side ofthe Car is Tilted almost 3 inches higher then the Left , So the Car is like tilited to the left - cos Both the Rear Shock up is Diffrent - one is KONI - there other is No idea what brand is it ?
i am looking for a Comfort Ride - and advice point to using s OIL perssure Shock up . any comment ?
is KYB ok ? i would be travelling alot in the CAR - how to get a comfort control Ride Smile
What you mean by Wheel Width ?
sorry for the MUCH question . i really got no idea Yet
OSIX
Previous Topic:"DEFECT" MR2
Next Topic:Adding Wing to TA22 - WHat Exterio Insatllation is NICE
Current Time: Fri Nov 20 04:32:02 UTC 2026
Total time taken to generate the page: 0.0063948631286621 seconds
