Toymods » Tech & Conversions » Corolla idle problem ??
beast
Corolla idle problem ?? Mon, 13 January 2003 12:35 Go to next message
Hey guys i have a corolla twin cam 87 model and since i have brought it it has had this idle problem not all the time just some times. Like after i have been hammering along sometimes it starts to idle weird like it will go up and down then stall then up and down stall i have no idea what the problem is neither do my mates and together we have had like 5 corollas same kind ?? if anyone has any helpfull input i would appreciate it!!.
thnx alot Shane Smile
beast
Re: Corolla idle problem ?? Tue, 14 January 2003 10:30 Go to previous messageGo to next message
So no one has any ideas about the problem i am having ??
Shane
xpimp
melbourne
Re: Corolla idle problem ?? Wed, 15 January 2003 15:51 Go to previous messageGo to next message
I have this problem too, and my overheating
I am guessing its the electronic points :/
ill tell u once i find a cure for mine
Fat_KE70
Shepparton
Re: Corolla idle problem ?? Thu, 16 January 2003 12:31 Go to previous messageGo to next message
a similar thing happened to mine when i had it and it was a head gasket!
it seems the oxy sensor doesnt like coolant!
rollaboy
Coffs
Re: Corolla idle problem ?? Thu, 16 January 2003 13:06 Go to previous messageGo to next message
I'm pretty sure this is a common prob on the AE82 Twin cam corolla's.
Mine does it too.
Here's a link that may help.
http://pub131.ezboard.com/ffwdtoyotafrm2.showMessa ge?topicID=2257.topic
Brett
xpimp
melbourne
Re: Corolla idle problem ?? Thu, 16 January 2003 14:33 Go to previous messageGo to next message
Mine isnt a EFI model its a 4AC so it cant be the oxygen sensor
its got to be points or something with the dist, its not the carby im sure
beast
Re: Corolla idle problem ?? Mon, 20 January 2003 05:40 Go to previous messageGo to next message
Thnx for ur help guys i am trying some things at the moment will let u know if i have any luck Smile
Shane
Corolla Boy
Re: Corolla idle problem ?? Mon, 20 January 2003 07:36 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 20 January 2003 07:37]
xpimp
melbourne
Re: Corolla idle problem ?? Mon, 20 January 2003 10:53 Go to previous messageGo to next message
Deleted due to previous post been deleted
[Updated on: Mon, 20 January 2003 10:54]
Re: Corolla idle problem ?? Mon, 20 January 2003 22:25 Go to previous messageGo to next message
my mums AE82/4AC had this problem.... it ran fine then in traffic it would not idle.. you need to hold your foot down a bit to keep it going or it stalls. a few more weeks, then it would stall while driving.. leave it 30 mins or so and it would maybe start, maybe not...
first thing i did was clean out the EGR valve in case it was dumping exhausty into the intake... helped a bit but not much...
then on friendly advice i replaced the dizzy ignitor (the black plastic thing on the outside with four spade lugs). suddenly starts and runs like a dream and has for about 6 months...
advice was it was a common problem for these dizzys...
try to borrow one that you know is good, see if it works.
beast wrote on Mon, 13 January 2003 23:35
Rowan
Re: Corolla idle problem ?? Tue, 21 January 2003 04:45 Go to previous messageGo to next message
itmay be something to do with the throttle body. my mate had a simmilar problem,so we swapped part of the throttle body with the same part from another twin cam and the problem went away.
xpimp
melbourne
Re: Corolla idle problem ?? Wed, 22 January 2003 10:47 Go to previous messageGo to next message
I dont think mines the dizzy... runs 100% cept when idling after awhile of driving...
Symptoms:
After it gets mediumly hot the idle gets erractic and falls to about 450rpm, thus starting to stall.... Yet it comes and go's and doesnt appair when not idling
Any ideas? is there any particular point on the carby u would look?
[Updated on: Wed, 22 January 2003 10:48]
Re: Corolla idle problem ?? Thu, 23 January 2003 23:20 Go to previous message
i didn't think it was either...
and you are describing the symptoms exactly...
if it starts doing it more often or completely dies while driving or refuses to start sometime, check the dizzy ignitor..
if at all possible, borrow an ignitor and try it...
if it was on the carby, it would either be the idle circuit being blocked intermittently (maybe crap in the float chamber) or it could be the EGR stuffing too much exhaust back into the intake (have a look at a manual for the diagram.. it lets exhaust in only after warmup..)
Previous Topic:GZE wiring
Next Topic:1mz-fe tranny.
Current Time: Mon Oct 26 13:45:59 UTC 2026
Total time taken to generate the page: 0.060026884078979 seconds
