Toymods » Tech & Conversions » 3S-GTE with 2S sump oil leaks
3S-GTE with 2S sump oil leaks Sun, 06 November 2005 21:43 Go to next message
Hey all, hows it going? Quick question for all of you out there who has done the rwd 3sgte conversion using a 2s sump.
The 2 holes at the back of the 2s sump that have to be filled, well I filled those up with weld and grinded flat.
But there doesn't seem to be enough clamping pressure at the back of the sump anymore, and has a persistant oil leak from around that area.
Has anyone come up with any fixes for this?
Maybe a 2S rear main housing, so those holes can be used? Or more gasket goo?
Or is there enough meat to tap into the 3S rear main seal housing and put an extra bolt in there?
Joel
Re: 3S-GTE with 2S sump oil leaks Sun, 06 November 2005 23:08 Go to previous messageGo to next message
Is it definetly leaking from the sump? Mine appeared to be leaking from the sump but was actually the rear main seal.
Re: 3S-GTE with 2S sump oil leaks Sun, 06 November 2005 23:48 Go to previous messageGo to next message
I had the same problem Joel. I ended up extending the flat plate at the back so that I could bolt it on.
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 00:28 Go to previous messageGo to next message
So you extended it, and then tapped some holes in the alloy main seal thing?
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 00:38 Go to previous messageGo to next message
There is already tapped holes in the alloy seal holder thing!
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 00:58 Go to previous messageGo to next message
The 3s one already has holes? My gen2 doesn't Sad
Even the factory 3sgte sump didn't have any bolt holes at the back there. But there was a bit more meat on the back of the sump I assume to help sealing it up.
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 01:18 Go to previous messageGo to next message
You got ripped off then Confused Mine has the tapped holes there. I'll find some photos when I get home.
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 01:35 Go to previous messageGo to next message
Here are a few pics.. Note the 3S sump doesn't have any bolt holes at the back of it.
2S on the left, 3S on the right.
http://img174.exs.cx/img174/1066/2ssump3ssump7yf.jpg
http://img227.exs.cx/img227/6205/3ssumponblock3nd.jpg
http://img228.exs.cx/img228/5611/2ssumponblock0lf.jpg
http://img228.exs.cx/img228/1450/2sumpholes3hh.jpg
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 02:25 Go to previous messageGo to next message
Interesting Confused See the Gen 3 had an alloy sump.
Maybe you could just drill and tap some holes in the alloy seal holder. Or use more goop Rolling Eyes
CelicaRA45
nth ringwood, Victoria
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 04:58 Go to previous messageGo to next message
joel make sure the sump is flat before you put the toyota packing material on it make sure you put heaps ,big bead at the back and when it tightens up you shoud not have a problem PS dont use silastic aint no good and make sure the sump surface is clean and has no oil on both contact surface es as the packing material will not go off and set
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 05:02 Go to previous messageGo to next message
Hmm whats packing material? As I did just use black goo?
CelicaRA45
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 05:07 Go to previous messageGo to next message
its the stuff that toyota sells for these sumps about 30.00 a tube and its black, red is for automatic transmission s
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 05:23 Go to previous messageGo to next message
Ahh ok.. Hmm sounds like off with the sump again and get some of this packing material.
Joel
TA22-3SGTE
MACKAY
Re: 3S-GTE with 2S sump oil leaks Mon, 07 November 2005 11:48 Go to previous message
I'v done a few of these now and never had any trouble with leaks , If you clean both surfaces with thinners and apply a bead of Locktite Black Max it will never leak .
Trevor
Previous Topic:CAI on Toyota Camry 93
Next Topic:gz-10 soarer body Q
Current Time: Sat Oct 24 02:26:29 UTC 2026
Total time taken to generate the page: 0.0061700344085693 seconds
