Toymods » Tech & Conversions » SETup for 4AGZE / W55 Gbox into AE86 ??
sprinter ae86gt
SETup for 4AGZE / W55 Gbox into AE86 ?? Mon, 07 November 2005 11:22 Go to next message
Hi
I was wondering if anybody knows the exact combination for fitting a W55 supra G/box up to a 4AGZE and then into a AE86 with the standard JDM tailshaft.
What G/Box bell housing recommended?
What G/box aft mount required / recommended ?
What clutch would be recommended for this running a 100KW flywheel ?
Can the JDM tailshaft be used without any mods, if mods what mods?
Would the engine need to be moved forward slightly for g/box bellhousing clearance or would the standard mounting position be fine.
Also what radiator ( ie 3 core etc) is an easy fitup so as to allow for the intercooler piping to pass between the radiator support pannel and radiator without and cutting of the pannels?
Big T
Re: SETup for 4AGZE / W55 Gbox into AE86 ?? Mon, 07 November 2005 11:54 Go to previous messageGo to next message
sprinter ae86gt wrote on Mon, 07 November 2005 22:22
Hi
Dellow,niteparts and Bill Sherwood has them from time to time. The brand you get will determine which clutch fork/release bearing you use
Need a custom box mount.
Depends on the power. Generally a 3-5 puck brass button with high clamp pressure plate (ie 1600lbs+) You'll need a 212 disk with 22 x 28.5mm centre.
No. You might be able to re-use the back half but you need the yoke off the w55 to make a new tailshaft. Make sure you get it balanced properly.
Standard should be fine.
Measure it and then have a field day at the wreckers.
Eddie.
ps you could've found all this by searching but im bored atm Smile
Henn
Rosanna, Melb
Re: SETup for 4AGZE / W55 Gbox into AE86 ?? Mon, 07 November 2005 12:54 Go to previous message
Consider yourself very lucky that Big T supplied all that info so clearly and concisely before anyone told you to search first. It has all been covered before.
As for radiators, a Gemini rad works perfectly and comes in 2 core and 3 core (from airconditioned models). No idea which model Gemini it came from though.
Hen
Previous Topic:MA61/RT142 suspension interchangeability
Next Topic:4Y-E wiring diagram (motor from 89 Tarago)
Current Time: Tue Oct 20 22:37:30 UTC 2026
Total time taken to generate the page: 0.11583280563354 seconds
