Toymods » Tech & Conversions » Will beams 3sge pistons work with gen 3 3sge
eurospec86
Barbados
Will beams 3sge pistons work with gen 3 3sge Mon, 07 November 2005 12:39 Go to next message
Heh guys im curious as to if the beams 3sge pistons can pe used in older 3sges like gen 2 and gen 3 engines, are the pistons the same design except for compression?, is pin size the same?, what about the valve angle of old heads and beams head? Can i just use beams pistons as a straight swap? Thanks for info guys, also are rods in beams lighter or the same?
gemtoy
melb
Re: Will beams 3sge pistons work with gen 3 3sge Mon, 07 November 2005 22:16 Go to previous messageGo to next message
From what I know I would say you cannot use the beams pistons. The valve angle is different on the beams head.You would have to flycut the pistons to stop the valves hitting the pistons.
CelicaRA45
nth ringwood, Victoria
Re: Will beams 3sge pistons work with gen 3 3sge Tue, 08 November 2005 06:16 Go to previous messageGo to next message
you can use the rods they will be ok .the pistons are nearly flat top with fly cuts as the pentroof in the head has changed so you would be dropping the compression from the gen 2 from10 to 1 to 9to 1 with these beams 1s
eurospec86
Barbados
Re: Will beams 3sge pistons work with gen 3 3sge Tue, 08 November 2005 12:07 Go to previous messageGo to next message
Thanks for the reply guys
KE20 BLACKTOP
Finland
August 2005
Re: Will beams 3sge pistons work with gen 3 3sge Tue, 08 November 2005 19:19 Go to previous messageGo to next message
anyone have 3s-ge blacktop beams pistons diameter?pinheight ect...
[Updated on: Tue, 08 November 2005 19:20]
CelicaRA45
Re: Will beams 3sge pistons work with gen 3 3sge Wed, 09 November 2005 05:57 Go to previous messageGo to next message
same pin height as gen 2 and 3
eurospec86
Barbados
Re: Will beams 3sge pistons work with gen 3 3sge Wed, 09 November 2005 11:45 Go to previous messageGo to next message
does anybody sell high comp pistons for the 3rd gen?
TerryOBeirne
Redbank Plains,near Ipswi...
Re: Will beams 3sge pistons work with gen 3 3sge Thu, 10 November 2005 10:14 Go to previous messageGo to next message
plenty of US makers have them, eg arias, weisco, Ross. we have built several race 3SG engines . contact me at work if you want anything serious. roadandtrack@hypermax.net.au
eurospec86
Barbados
Re: Will beams 3sge pistons work with gen 3 3sge Thu, 10 November 2005 12:27 Go to previous message
ygm
Previous Topic:overspray
Next Topic:K&N for AE101 20V
Current Time: Sun Nov 22 20:53:47 UTC 2026
Total time taken to generate the page: 0.0051028728485107 seconds
