Toymods » Tech & Conversions » ge head on gze??not 4 turboh!!!
jaydik
ge head on gze??not 4 turboh!!! Tue, 08 November 2005 01:46 Go to next message
here's the deal, i bought a gze from malaysia 4 me 86, fel off the back of the ute as i was bringing it home,(long story my dad's fault) and cracked the ignition system, and cam gears on impact, so i'm guessing the rest of the head is screwed. Being a small port gze i red i can use my small port 100kw head currently in my 86.
The question is will it run the same as the gze original or will there need to be mods or specific re-tuning to be completed to the head so it will work?
also is it possible to run a dizzy setup instead of the coil packs (think thats what their called) currently smashed on the gze? reason i ask is cause i wanna save $$$ as i have a 4age setup in 86 at da mo.
My 4age currently runs off an ems stinger, mixed opinions so far about retaining it 4 the gze or just using a standard gze ecu. any suggestions? it also has a 175mm pulley and F.C.P piece.
any help would be great
fatmr2
Re: ge head on gze??not 4 turboh!!! Tue, 08 November 2005 06:16 Go to previous messageGo to next message
No Message Body
[Updated on: Tue, 08 November 2005 06:23]
fatmr2
i used a bigport ge head on a bigport gze block and there was no modification and it worked fine.
jaydik
Re: ge head on gze??not 4 turboh!!! Tue, 08 November 2005 07:03 Go to previous messageGo to next message
were you running the sc with standard ecu???
myne
October 2005
Re: ge head on gze??not 4 turboh!!! Tue, 08 November 2005 08:02 Go to previous message
Cant you just grab a crank angle sensor and some coils?
AFIK it wouldnt work without the CAS because the ecu uses that for injector timing too.
Previous Topic:Hybrid VS MA70 Intercooler
Next Topic:AE101 LEVIN GTZ WIRING DIAGRAM
Current Time: Mon Oct 19 02:00:09 UTC 2026
Total time taken to generate the page: 0.0050969123840332 seconds
