Toymods » Tech & Conversions » a few 4agze q's
nb86
melbourne
    sadff
a few 4agze q's Tue, 08 November 2005 06:53 Go to next message
i just picked up a sprinter running a 4agze (dizzy type) and a haltech e6k. the car was running a huge monster tacho which ive removed but im unsure if the factory tach can run from the coil signal. any ideas on modifications or if it will run. also the SC switch is currently a manual switch on the dash, anyone had slutions for running a load based setup like the factory?
jaydik
Re: a few 4agze q's Tue, 08 November 2005 07:10 Go to previous messageGo to next message
dude i read somewhere on this forum that some1 was selling a gadget that allowed the signal to run with the standard sprinter dash, was about $97 plug n play type.
do a search on tech section 'gze tacho' or sunthin
sideshow
Re: a few 4agze q's Tue, 08 November 2005 08:01 Go to previous messageGo to next message
nothin is plug and play for the sprinter
i have a device which i have used on sprinters with 4agzes and std ecu
but if u havea dizzy type 4age u should be able to connect the black tacho wire straight to the neg side of the coil
its only on multiple coils u need this device
to get the sc working u need to get one of the haltechs aux outputs to trigger the sc relay
im guessing that whoever did the wiring was a dumbass and didnt know what to do
why have it on a fukin switch
for a basic setup just fit the switch to yr accel pedal
so it cuts it on when u gave full throttle
much easier unless u want to spend money and do it properly
Henn
Rosanna, Melb
Re: a few 4agze q's Tue, 08 November 2005 10:43 Go to previous messageGo to next message
How to switch your SC.
As sideshow says, your dash tacho should work fine from the dizzy.
And the search function (or Google) is your friend.
Hen
nb86
melbourne
    sadff
Re: a few 4agze q's Wed, 09 November 2005 04:54 Go to previous message
tacho works, like i thought (and you guys too). it just wasn't hooked up Razz thanks hen, thats exactly what i was after, couldn't find anything on the search for some reason though, cheers. from what i can gather the output of your circuit is high when the ecu aux out goes low (ie reversed) is that right?
[Updated on: Wed, 09 November 2005 04:58]
Previous Topic:URGENT: power steer help
Next Topic:4A-C stalling on idle after drive
Current Time: Sat Oct 31 16:23:29 UTC 2026
Total time taken to generate the page: 0.0042359828948975 seconds
