Toymods » Tech & Conversions » help on engine conversion
ghost_89918
Mahe
November 2005
help on engine conversion Wed, 09 November 2005 16:17 Go to next message
I have a KE30 with no engine. I want to put 4AGE engine in it, is it possible. If yes where can I get more info for doing the conversion and would it make a difference if I got a RWD engine instead of getting a FWD and making it to a RWD??
Re: help on engine conversion Wed, 09 November 2005 17:44 Go to previous messageGo to next message
check out the FWD to RWD tech doc..
ys.. many pl have done it.. ppl have even put 1GGTE's in..
have a look around the forums (use google to search it)
BradW
Bottom of the hill, Sydney
Re: help on engine conversion Thu, 10 November 2005 10:16 Go to previous messageGo to next message
I am in the process of doing this. Have a look at the link in my sig. My conversion is a long way from being finished but it will give you a bit of a guide.
A rwd drive 4age would make the conversion easier. I would suggest also speaking with an engineer about what is required to get the car registered ( that's if you need rego, where is Mahe? ).
ghost_89918
Mahe
November 2005
Re: help on engine conversion Thu, 10 November 2005 16:20 Go to previous messageGo to next message
Mahe is in Seychelles, which is located in the Indian Ocean. I don't need to worry about registration here.
If I get a RWD 4AGE engine (which cars are they found in??) what else would I need to get/buy to make the conversion successful?
My KE30 has only 2dr I think it is a coupe.
Re: help on engine conversion Thu, 10 November 2005 19:47 Go to previous messageGo to next message
ghost_89918 wrote on Fri, 11 November 2005 03:20
*so* wanna live there
rthy
Melbourne - NthSubs
Re: help on engine conversion Thu, 10 November 2005 23:01 Go to previous messageGo to next message
4ages come in corollas, sprinters, etc... not sure if its the same as to what guy have down on your side of the world... Wink
u will also need a efi fuel pump and fuel pump relay
ghost_89918
Mahe
November 2005
Re: help on engine conversion Fri, 11 November 2005 12:03 Go to previous messageGo to next message
Do you know of any site that holds info on how to do the RWD 4AGE conversion on a KE30 similar to mine?
rthy
Melbourne - NthSubs
Re: help on engine conversion Fri, 11 November 2005 12:07 Go to previous messageGo to next message
there alot in this one
u should look on the search or google.com
"4age ke70" or "4age ke55" or "4age ke30"
should come up with something
http://forums.toymods.org.au/index.php?t=msg&t h=78592&rid=4430&S=bac85854a6eef6174cf3c1e 2529ce261&pl_view=&start=0#msg_744420
ghost_89918
Mahe
November 2005
Re: help on engine conversion Fri, 11 November 2005 13:10 Go to previous messageGo to next message
I've been searching for the past 2 hours and I have still not found, any site containing info about a 4AGE conversion in my specific model. Someone please help me.
shinybluesteel
melbourne
Re: help on engine conversion Fri, 11 November 2005 13:14 Go to previous message
it's time to give up now, it is pretty straightforward, but will require some actual work to do in regard to engine mounts, gearbox/tailshaft matching, EFI fuel system etc.
might be hard to find someone to hold your hand, take it to a semi decent mechanic or something.
Previous Topic:HOW MUCH???
Next Topic:4agze problems
Current Time: Tue Oct 27 10:15:38 UTC 2026
Total time taken to generate the page: 0.04180908203125 seconds
