Toymods » Tech & Conversions » 4AC alternator bracket on a RWD 20v issues
domasik
4AC alternator bracket on a RWD 20v issues Thu, 10 November 2005 03:30 Go to next message
ive got the alternator bracket on and it lines up with my 4ac crank pull fine but it has 3 mounting holes and the one on the top right uses the same hole as my engine mount. id imagine the standard 4a engine mounts use the same holes so how is the problem overcome?
pics coming very soon
domasik
Re: 4AC alternator bracket on a RWD 20v issues Thu, 10 November 2005 03:49 Go to previous messageGo to next message
the bolt circled is the one also required by my engine mounts. now im pretty sure they 4ac uses the same holes for its mount how on the 4ac is this overcome?
http://www.fluidzone.com/liddertown/pics/alternator01.jpg
http://www.fluidzone.com/liddertown/pics/alternator02.jpg
http://www.fluidzone.com/liddertown/pics/alternator03.jpg
4a-c
Sutherland Shire
Re: 4AC alternator bracket on a RWD 20v issues Thu, 10 November 2005 04:28 Go to previous messageGo to next message
cant remeber which way but the engine mount either goes on top or put it on before the alternator bracket. one of those two
Jonny2TG
Tasmania
Re: 4AC alternator bracket on a RWD 20v issues Thu, 10 November 2005 07:54 Go to previous messageGo to next message
If useing a 4AC alternator bracket on the 20valve, you need to grind part of the mount at the top to fit, and use the RWD waterpump.
4a-c
Sutherland Shire
Re: 4AC alternator bracket on a RWD 20v issues Thu, 10 November 2005 08:16 Go to previous messageGo to next message
never had to do any grinding on mine
domasik
Re: 4AC alternator bracket on a RWD 20v issues Thu, 10 November 2005 15:14 Go to previous message
ive worked out how to do it but to make it work i need to modify my engine mount slightly.
the 2 bolts that are on top of each other, ill put 2 washers inbetween the bracket and the block and bolt the other part of the bracket over the top of my engine mount.
if u look closely you will see im actually using a RWD water pump and already have a 4AC crank pulley.
will post photos on saturday but thanks for your help guys.
Previous Topic:Wiring 2jzge into 260z
Next Topic:Toyota Diff Codes ?
Current Time: Thu Nov 26 07:09:07 UTC 2026
Total time taken to generate the page: 0.0057311058044434 seconds
