Toymods » Tech & Conversions » Rough-running problem fixed on the SE-86
Bill Sherwood
Brisbane / Gold Coast
Rough-running problem fixed on the SE-86 Thu, 10 November 2005 06:30 Go to next message
The Altezza 3SGE in my Sprinter has had a constant rough-running problem at part throttle ever since it's gone into the car, and the last thing we were going to try was to make a mesh to straight the airflow going over the hot-wire AFM in the inlet pipe, as we suspected there was turbulence affecting the signal it was sending tot he ECU.
So!
Cheap-arse mesh made - From $0.94 of drinking straws. Very Happy
I also got the cheapest superglue I could find, hoping that I could get it to 'wick' its way through the bundle of straws. Fortunately, it seemed to quite well.
So, armed with a 70mm diameter glued-up bundle of drinking straws, I shoved the mesh up the inlet of the Sprinter and went for a drive.
And it works perfectly now!!!
Yee-friggen-ha!!!
So I've cut the bundle in half to make it fit into the pod air filter and added some flyscreen mesh over the upper end to stop any loose straws from getting sucked into the engine.
Here's the Bill-Tech mesh, just before fitting ->
http://www.billzilla.org/ae86strawinlet1.jpg
And here it is just before putting the air filter back on, taking from under the car.
http://www.billzilla.org/ae86strawinlet2.jpg
So at least the damned thing drives nicely now, I can get out & about in it some more - Once I get it re-registered. Smile
FWIW here's the engine in the car ->
http://www.billzilla.org/ae863sgebay4.jpg
Re: Rough-running problem fixed on the SE-86 Thu, 10 November 2005 07:00 Go to previous messageGo to next message
Ghetto engineering, Billzilla style - I'm loving it!
BTW, your car is an AE86, and thus has a 4A engine in it, so this may have been the source of your initial confusion. Hope that helps.
pr1nce
NSW, Sydney
Re: Rough-running problem fixed on the SE-86 Thu, 10 November 2005 07:41 Go to previous messageGo to next message
that is bad ass.
shinybluesteel
melbourne
Re: Rough-running problem fixed on the SE-86 Thu, 10 November 2005 08:31 Go to previous messageGo to next message
get some alluminium stuff bill, do it properly Razz
and put the battery in the boot for goodness sakes.
looking good, is it faster than it was with the monster 4AGE yet?
Blown86
Re: Rough-running problem fixed on the SE-86 Thu, 10 November 2005 12:17 Go to previous messageGo to next message
Huge opportunity there!!
Call it a mega Ueo-Dori drift mod, paint them pink, flog the straws for $300 and you'll be able to retire.... Very Happy
Re: Rough-running problem fixed on the SE-86 Thu, 10 November 2005 12:45 Go to previous messageGo to next message
Bill, this may be a couple of stupid questions but....
how far away from the sensor can this be and still be effective??
did you ever try just a plain restrictor in the inlet path?
Bill Sherwood
Re: Rough-running problem fixed on the SE-86 Thu, 10 November 2005 14:17 Go to previous messageGo to next message
shinybluesteel wrote on Thu, 10 November 2005 19:31
Yes, I'll be fitting some alloy mesh when I can find the right stuff for it.
Why would I want to put the battery in the boot? It's fine where it is.
No, it's not as fast as the 4AGE I had in the car. Certainly doesn't sound as good either. Smile
oldcorollas wrote on Thu, 10 November 2005 23:45
Don't know how far away but as long as the sensor is in the lnlet I don't think they're too fussy. No I haven't tried a restrictor, what would that do?
Re: Rough-running problem fixed on the SE-86 Thu, 10 November 2005 21:44 Go to previous messageGo to next message
restrictor might introduce new turbulence after the tubing widens to the sensor
maybe use the honeycomb from a karmann vortex type afm 7mgte 1uzfe
but hey straws work Smile
ed_ma61
Lost in the K hole
Re: Rough-running problem fixed on the SE-86 Thu, 10 November 2005 21:50 Go to previous messageGo to next message
the guts of an old cat converter perhaps??
myne
October 2005
Re: Rough-running problem fixed on the SE-86 Fri, 11 November 2005 01:11 Go to previous messageGo to next message
That takes dodgy to a new level - you ought to be ashamed of yourself!
Just out of intrest, what exactly makes this sort of thing work?
Is it the restriction? Is it the increase in wind velocity like a venturi?
Surely a proper tune would be the most effective?
Re: Rough-running problem fixed on the SE-86 Fri, 11 November 2005 02:10 Go to previous messageGo to next message
he is runnign the stock ecu cant get a better tune than that exclamation mark exclamation mark exclamation mark
multiple small resistances in parallel will reduce total resistance i doubt there would be a significant pressure drop across the straw bundle if there is i would suggest cutting the straw bundle the proprietary honeycomb is very short
the straws or honeycomb act to make the airflow linear rather than turbulent if the airflow across the hotwire is turbulent this will wreak havoc with the ecus abiltiy to determine afr rough running is the result
[Updated on: Fri, 11 November 2005 02:22]
Bill Sherwood
Re: Rough-running problem fixed on the SE-86 Fri, 11 November 2005 03:36 Go to previous messageGo to next message
As far as I can tell there's very little restriction with the straws as such. But they're only temporary and I'll come up with something permanent later on.
But for the moment I'm just happy to drive the thing around like normal car for a while. Very Happy
Re: Rough-running problem fixed on the SE-86 Fri, 11 November 2005 06:00 Go to previous messageGo to next message
gianttomato wrote on Fri, 11 November 2005 13:10
Bill, i guess i was wondering, how long the airflow stays liner befor it begins tumbling again... it looks like you have a 90 deg turn between the straws and the hotwire, which made me wonder if it will still be laminar flow...
or if the issue was more of a problem of having unequal flow between top and bottom of pipe (and subsequent slight difference in hotwire reading) from air favouring the top of the pipe after turning 90deg (but only at part throttle.. idle is less flow, WOT is much more, so the distribution of flow in those cases becomes more even?) and also wondering if the slight restriction was enough to affect this, moreso than the straightening?
but maybe i am barking up wrong tree Wink feel like doing a smoke test?? Razz
RobertoX
Re: Rough-running problem fixed on the SE-86 Fri, 11 November 2005 06:12 Go to previous messageGo to next message
Stu isn't that the afm right after the straws (the plug in the second pic down) or am I looking at the wrong thing?
How long did it take you to to figure out that it was turbulence in the inlet affecting the sensor bill? I think I would have been scratching my head for quite a while!
Oh, and does that radiator flow left-right rather than up-down?
MR 1JZ
Re: Rough-running problem fixed on the SE-86 Fri, 11 November 2005 07:16 Go to previous messageGo to next message
hahaha its so ghetto-tastic I love it!
Bill Sherwood
Re: Rough-running problem fixed on the SE-86 Fri, 11 November 2005 07:25 Go to previous messageGo to next message
Yes the AFM is down near the bottom of the steel tube (you can see the wires coming out of it in the second photo)so the straws are very close to it.
It took a while to guess what it was. Initially we had three suspects -
1. Fuel pressure. Manged to find out what it should be and set it to 62psi, no changes.
2. Oxygen sensors. There's two of them and for a while we thought that maybe they'd gone back in their holes in the wrong spot. (one probe does cyls 1 & 4, the other cyls 2 & 3) I disconnected them to see if it'd make any difference and it didn't. After digging through some old build photos I found that we did indeed put them back into the wrong holes and after a bit of cursing and swearing found that it was bloody nearly impossible to swap them back over without pulling half the the bits & pieces off the engine on that side. So we ended up just swapping over the plugs, as they only go in one way. Wink
3. The last one was turbulence in the inlet, and a few days ago I took the pod filter off to see if it'd make any difference as to how the car drove. It did; It was barely driveable so I thought I might be onto something there.
A bunch of straws, superglue, rubber bands, and tape later and I knew we'd fixed it.
Fug it feels good. Very Happy
Now to get the speedo working, the big rear brakes (pick up the new discs tomorrow) and a few other things and the car will be in bloody good condition again.
Re: Rough-running problem fixed on the SE-86 Fri, 11 November 2005 07:44 Go to previous messageGo to next message
Bill Sherwood wrote on Fri, 11 November 2005 18:25
ahh, my apologies.. now that i've managed to find 4 hrs sleep in last two days, i can actually see the wires Razz
heh heh, nothing like solving abstract problems Very Happy
can't wait to see it.. in a couple of years Wink
Re: Rough-running problem fixed on the SE-86 Fri, 11 November 2005 09:30 Go to previous messageGo to next message
love your use of punctuation gt
no_tofu_speed
Jab what?!!?!
Re: Rough-running problem fixed on the SE-86 Wed, 16 November 2005 22:19 Go to previous messageGo to next message
Interesting..........
So a non ghetto-tastic job if one had the money and time to fix this. How would one go about it, instead of the straws.
Re: Rough-running problem fixed on the SE-86 Wed, 16 November 2005 22:24 Go to previous messageGo to next message
gianttomato wrote on Fri, 11 November 2005 08:44
read the thread
no_tofu_speed
Jab what?!!?!
Re: Rough-running problem fixed on the SE-86 Thu, 17 November 2005 05:19 Go to previous messageGo to next message
missed that bit. sheesh sorry.
Re: Rough-running problem fixed on the SE-86 Thu, 17 November 2005 05:39 Go to previous messageGo to next message
haha
tricky
July 2005
Re: Rough-running problem fixed on the SE-86 Thu, 17 November 2005 05:58 Go to previous message
oldcorollas wrote on Fri, 11 November 2005 17:00
won't ever be laminar oldcorollas. The straws remove some of the vortex/swirls, but strictly speaking, the flow regime will remain turbulent. Very Happy
Previous Topic:AE82 Parts
Next Topic:jza stock diff ratio ?
Current Time: Wed Oct 14 04:49:25 UTC 2026
Total time taken to generate the page: 0.051408052444458 seconds
