Toymods » Tech & Conversions » 20V alternator wiring
Sam_Q
S.E suberbs, Vic
20V alternator wiring Fri, 11 November 2005 07:11 Go to next message
I am trying to wire up a 20V Alterntor and I think I have figured out which wire is which in my ae-86 body however I dont know which wire is which on the alternator, could someone please tell me which is which, thanks (and yes I searched)
4ag20t
Re: 20V alternator wiring Fri, 11 November 2005 10:16 Go to previous messageGo to next message
You will need to connect all 3 wires in the plug on the 20v alt.
There should be a sticker on the alt as i can't remember which is what at the moment. They will be L = charge light
I = ignitin feed
S = battery 12v
to chech you have the correct wire on the car, turn on the ignition and using a test light ground the wire, if it brings on the charge light..you found the correct wire.
will have a look at an alt in the morning and tell you the positions on the alt.
Re: 20V alternator wiring Sat, 12 November 2005 12:44 Go to previous messageGo to next message
It's a long time since I looked at this, but I THINK the wire for the light is on the same 2 pin plug that originally went to the carb. I and S (sense) are fairly easy to find a home for.
sideshow
Re: 20V alternator wiring Sat, 12 November 2005 19:29 Go to previous messageGo to next message
red/blue is ignition
yellow is light
white is battery supply
Re: 20V alternator wiring Sun, 13 November 2005 01:31 Go to previous messageGo to next message
find the 6 pin plug where your external voltage regulator was once connected (it should now be removed).
From the 3 pin plug off the alternator, you will have:
S - battery voltage sense
Ign/I - Ignition
L - charge light
these three are to be wired to the wires in the 6 pin plug which sideshow has just outlined.
All done.
here is a picture.
http://www.witzl.com/PMP80Y/4age/ALternator%20wiring.jpg
Black_KE70
Gold Coast Australia
October 2005
Re: 20V alternator wiring Sun, 13 November 2005 01:45 Go to previous messageGo to next message
The 20V alternator should be an internally regulated internal fan unit. if you look at the plug on the alternator
(nippon denso 3 pin regualtor)
I always remember : LEFT EYE = LIGHT (LEFT EYE OF SMILEY FACE)
light ignition
sense
Note this is when you are looking at plug from rear of alternator. Sense will run straight to the battery and will normally be white.
Light will be yellow and runs into the car to dash etc ect...
Ignition will be either blue or red (or a combintaion)
Sam_Q
S.E suberbs, Vic
Re: 20V alternator wiring Sun, 13 November 2005 10:33 Go to previous messageGo to next message
thanks guys, I will look at it as soon as I can, I have been sick lately.
Sam_Q
S.E suberbs, Vic
Re: 20V alternator wiring Sun, 27 November 2005 13:21 Go to previous message
well I managed to wire this up but I still have one spare wire
off this plug theres 2 large white wires, one goes to the fuse box and I need to use it but the other goes into the body loom, does anyone know where this goes and what it does?
Previous Topic:dodgy gearbox
Next Topic:4agze and s/c oil
Current Time: Tue Oct 20 22:53:38 UTC 2026
Total time taken to generate the page: 0.0067901611328125 seconds
