Toymods » Tech & Conversions » 1jzgte vs 1jzgte vvti
lobby69
Thornleigh sydney
January 2005
1jzgte vs 1jzgte vvti Sat, 12 November 2005 07:16 Go to next message
so whats the big difference between them, i know, vvti and single turbo....
have heard rumours that the vvti's are unreliable....have a few probs,???
would the twin 1j be better with a single conversion then a vvti with a bigger single???
BLAKE Razz
terra
July 2005
Re: 1jzgte vs 1jzgte vvti Sat, 12 November 2005 09:43 Go to previous messageGo to next message
thats kinda dependant on the final level of tuning.
the vvti helps with the bottom end so i guess it MAY boost earlier.
being a newer engien, stronger / more refined parts?
Re: 1jzgte vs 1jzgte vvti Sun, 13 November 2005 05:35 Go to previous messageGo to next message
The VVTi engines are also higher compression; 9.0:1 vs 8.5:1 for the older 1JZ's. This combined with the VVTi will spool up any given turbo much faster. It's no coincidence that the VVTi makes max torque 2000rpm sooner than the 1JZ!
I haven't heard anything bad about their reliability. The internal construction of the engine is much the same.
lobby69
Thornleigh sydney
January 2005
Re: 1jzgte vs 1jzgte vvti Sun, 13 November 2005 06:32 Go to previous messageGo to next message
Norbie wrote on Sun, 13 November 2005 16:35
oh sweeet!!!
so the vvti is the way to go in most peoples eyes?
cheers, blake
Re: 1jzgte vs 1jzgte vvti Sun, 13 November 2005 06:41 Go to previous messageGo to next message
yes for a million reasons
Re: 1jzgte vs 1jzgte vvti Sun, 13 November 2005 08:18 Go to previous messageGo to next message
The only downside with the VVTi engines when it comes to modifications is (a) you need a high-end ECU to run the VVTi (eg Motec) and (b) there are fewer aftermarket cams available off the shelf. If you're OK with that the VVTi engine is definitely the way to go!
Re: 1jzgte vs 1jzgte vvti Sun, 13 November 2005 08:50 Go to previous messageGo to next message
hk$ make some intake cams for them definitely a 256 and possibly a 264 duration one exhaust side is same as non vvti
MR 1JZ
Re: 1jzgte vs 1jzgte vvti Mon, 14 November 2005 00:20 Go to previous messageGo to next message
harder to get aftermarket turbo manifolds as well as the VVTI head has different port spacing than the non VVTI head...
also wouldnt it be food for thought to maybe spend the difference in price on a VVTI engine on a big single turbo/computer/set of cams on a non VVTI motor as the price difference can be quite large...
Manny
Re: 1jzgte vs 1jzgte vvti Mon, 14 November 2005 00:42 Go to previous message
1JZ-GTE VVTi engines have a reputation for kicking rods in Japan, at much lower than expected power levels.
Restrictive AFM is a PITA to deal with as your stuck with it with the stock ECU due to VVTi control.
Headgasket apparently becomes marginal ~300rwkw unless tuning is spot on.
Previous Topic:RA28 LSD & Axle Question ???
Next Topic:Stripped thread
Current Time: Fri Oct 23 17:46:38 UTC 2026
Total time taken to generate the page: 0.093751907348633 seconds
