Toymods » Tech & Conversions » AE86 Indicator Lense
Initial_D
February 2005
AE86 Indicator Lense Sun, 13 November 2005 03:33 Go to next message
I want to remove the lense of the indicator (the one next to the parker). I took it off the car and took the little screw out at the bottom but still won't buge
Callifo
Gawler, SA
Re: AE86 Indicator Lense Sun, 13 November 2005 03:44 Go to previous messageGo to next message
You want to pull the lense off? Usually those things are pretty well sealed on?
ShiRi
Re: AE86 Indicator Lense Sun, 13 November 2005 04:46 Go to previous messageGo to next message
it begs the question, why do you need to remove it?
it's part of the parker... you can't take it out
Initial_D
February 2005
Re: AE86 Indicator Lense Sun, 13 November 2005 05:48 Go to previous messageGo to next message
I wanted to paint in with the black lens paint
Callifo
Gawler, SA
Re: AE86 Indicator Lense Sun, 13 November 2005 07:20 Go to previous messageGo to next message
Youd probably break the lense before you managed to pry apart the glue they use. Perhaps you could pour the paint inside and swish around and pour out. Id probably test its sealed properly though with water before just incase (otherwise you might end up with black parker as well or even black pants Wink )
ShiRi
Re: AE86 Indicator Lense Sun, 13 November 2005 07:33 Go to previous messageGo to next message
ever heard of tape and newspaper?
LiL_MiC
Melb
Re: AE86 Indicator Lense Sun, 13 November 2005 10:15 Go to previous messageGo to next message
it looks nice as is! Sad
Initial_D
February 2005
Re: AE86 Indicator Lense Sun, 13 November 2005 22:33 Go to previous messageGo to next message
Do most people paint the outside? Does it chip easy? If you need to remove the paint, can you?
taitran
Melbourne, West Suburbs
April 2005
Re: AE86 Indicator Lense Mon, 14 November 2005 23:31 Go to previous message
Yeah just mask surrounding areas and paint the outside.
It wont chip easily, just use some wax and grease remover and clean surface , u might also want to give it a clear coat, so it wont wash away.
Previous Topic:IS200 Engine Swap - opinions please! [The New Guy!]
Next Topic:how much to port, polish and shave 20V
Current Time: Thu Oct 22 11:55:46 UTC 2026
Total time taken to generate the page: 0.0047481060028076 seconds
