Classifieds » Parts Wanted » r154 box needed
ROBBO_ma61
r154 box needed Wed, 15 January 2003 08:58 Go to next message
Hey everyone
I am looking for a supra 5 speed r154 steel case box. Willing to pay decent $.
suprav8
melbourne
Re: r154 box needed Wed, 15 January 2003 09:29 Go to previous messageGo to next message
tippin you`ll need to make a new trans tunnel if your to fit that box under ya MA61 Smile
ROBBO_ma61
Re: r154 box needed Wed, 15 January 2003 09:30 Go to previous messageGo to next message
couldnt i just make the tunnel bigger by cutting it out ?
suprav8
melbourne
Re: r154 box needed Wed, 15 January 2003 09:42 Go to previous messageGo to next message
sure..you`ll still have to get a new one fabricated...If you want to use the R154 it`s going to cost you some big$$$
How much HP do you want and how do you intend to drive???
ROBBO_ma61
Re: r154 box needed Wed, 15 January 2003 09:46 Go to previous messageGo to next message
looking at minimum 400 from a 302 v8...too much torque for a w58 i am thinking and have been told. Want something tough and robust. steel case sounds right tho. how much bigger are we talking?
CLG
Perth, Western Australia
Re: r154 box needed Wed, 15 January 2003 09:54 Go to previous messageGo to next message
The R154is not a steel cased box, it's alloy cased with a steel sandwich plate. If you are worried about the trans tunnel, cut one out of a Falcon or Commodore with a column shift and cut the shifter hole where you want it. A bit a hammer and dolly work will be required to fit it in, but you will need to do this with any new trans tunnel. I took this option when fitting a celica steel case 5 speed into an EK Holden. We used a Holden HZ trans tunnel and welded it in for a neat finish.
Clint!
suprav8
melbourne
Re: r154 box needed Wed, 15 January 2003 10:01 Go to previous messageGo to next message
Bottom line dude.....if you are rich then go the R154 !!!!!
If you are not rich then put a top loader behind the 302!
Either way your diff ratio is going to be all wrong!!
Which ever way you go you`ll be doing nothing but changing gears all the time.
CLG
Re: r154 box needed Wed, 15 January 2003 10:07 Go to previous messageGo to next message
yeah, but a recond toploader wil cost you as much as the R154! You also have the problem of expossed shifter linkages to clear and keep clean so they don't wear. I know, I have both boxes and would happily go the R154 route especially having the overdriven fifth gear! Whats wrong with changing gears?!!!
suprav8
melbourne
Re: r154 box needed Wed, 15 January 2003 10:16 Go to previous messageGo to next message
Top loader is worth about half a R154!Then you have the expense of putting it behing the 302!!! $$$
nothing wrong with changing gears but going fron 2nd to 5th in about 10 seconds(of normal driving) is all bad! Smile
i`m not saying the top loader is the best option just the cheapest!......he won`t destroy it
ROBBO_ma61
Re: r154 box needed Wed, 15 January 2003 12:13 Go to previous messageGo to next message
fark man...whats tougher...a celica 5spd or a w58? Or is a r154 stronger than both? I want this thing to stay together thats why im wanting a tough box. I want to be able to race and blow away little 4cyl rice rockets namely silvias and hondas without things breaking. fucks me wat im gonna do...i havent even started yet...ive got a block and heads ready to go...so ive got time to decide. By the way...what the hell is a toploader?
[Updated on: Wed, 15 January 2003 12:13]
Re: r154 box needed Wed, 15 January 2003 12:25 Go to previous messageGo to next message
From strongest to weakest: R154, W58, W50. Their prices are 1500-2000, 3-600, and ~1-200 respectively.
ROBBO_ma61
Re: r154 box needed Wed, 15 January 2003 12:44 Go to previous messageGo to next message
fark me...are r154 that bloody dear? i might have to rethink my ideas if that is the case...a new falcon 5spd is probably not much more $ than that...
[Updated on: Wed, 15 January 2003 12:44]
CLG
Re: r154 box needed Wed, 15 January 2003 13:35 Go to previous messageGo to next message
Yet another joy of living in Perth. I bought my R154 for $1300, W58's are around $200 - 400, and W50's are $200 (lots of V8 boys still chase them?!?). A second hand Toploader can be purchased complete for around $600 - 700 (or recond for $850 bare). The Falcon 5 speeds are all generally T5 based and not worth a pinch, they seem to damage fifth quite easily, are mega expensive to repair, and there are lots of different varieties not to select due to their poor power handling characteristics.
My opinion: if you want the toughest 5 speed, as discussed here, spend the money and get the R154.
Clint!
ROBBO_ma61
Re: r154 box needed Thu, 16 January 2003 07:35 Go to previous messageGo to next message
i might have to talk to you about the parts there clint...from the other post i did...about clutch etc...Perhaps i could give you a call sometime?
CLG
Re: r154 box needed Thu, 16 January 2003 08:31 Go to previous messageGo to next message
Toploader gearboxes are the strongest production built four speed in the world. Ford made them for many different applications and there are quite a few different types to consider. I had a flick through my parts today and also have a spare 11" pressure plate, if you decide to go that way!
Robbo will send you a pm, regarding contact!
Clint
ROBBO_ma61
Re: r154 box needed Thu, 16 January 2003 09:18 Go to previous messageGo to next message
any idea if a toploader ford box wil fit in an ma16 trans tunnel? I suppose then theres the problem of gearshift location?
CLG
Re: r154 box needed Thu, 16 January 2003 15:40 Go to previous messageGo to next message
I have an article regarding the installation of a Windsor V8 and Toploader box into a RA23 - they state only minor "massaging" was needed. The R154 is a wider box than the toploader, but not overly so. The MA61 has a larger trans tunnel than the RA23 (just!), so fitment shouldn't be that difficult. Having said that, if you are picky about installation like me, replace the trans tunnel with something bigger.
Also don't expect to change gears super quick if you go the toploader route, especially if you are right handed - they use two detent clips that are quite stiff when replaced while the box is out of the car (cos they're a prick to do out of the car, and impossible to do in the car!).
I stand corrected on the clutch interchangability between W and R series gearboxes - they both have 21 spline input shafts. For some reason, I thought the R154 had a 23 spline input shaft, but I was wrong - thanks for the "heads up" to whoever got me checking!
Clint!
[Updated on: Thu, 16 January 2003 15:44]
celicamad85
Banned member
Re: r154 box needed Thu, 16 January 2003 20:08 Go to previous messageGo to next message
theres a few guys is the US running round 800hp and w58's still going strong
ROBBO_ma61
Re: r154 box needed Fri, 17 January 2003 07:48 Go to previous messageGo to next message
did anyone manage to get some measurements of a w58 and a r154 diameter etc?
kevz0r
Re: r154 box needed Fri, 17 January 2003 07:56 Go to previous messageGo to next message
celicamad85 wrote on Fri, 17 January 2003 04:08
Yep. Russ M in his high HP mk2 went through a number of R154 and W58's and reckons that they both have the same problems.
Could maybe use the W58 out of a Mkiv? Norbie? Smile
ROBBO_ma61
Re: r154 box needed Fri, 17 January 2003 08:17 Go to previous messageGo to next message
is the mk4 one any stronger?
Re: r154 box needed Fri, 17 January 2003 09:19 Go to previous messageGo to next message
ROBBO_ma61 wrote on Fri, 17 January 2003 19:17
Yes, Mk4 W58 has a larger input bearing.
Also, here is a photo comparison of the R154 and W58. To give you an idea, the W58 is approx 7" across the sandwich plate and the R154 is approx 9". The R154 is the one on the left.
http://www.speedtoys.com/~stryder/w58vsr154/w58vsr154.jpg
There is also a lovely pic showing the dimensions of the 2 boxes somewhere on the net but I can't find the link.
Cheers Dave.
[Updated on: Fri, 17 January 2003 09:32]
ROBBO_ma61
Re: r154 box needed Sat, 18 January 2003 01:26 Go to previous messageGo to next message
fuck me...its a lot bigger...NICE! Very Happy Gotta love those steel cases! will see what i can do...HAS ANYONE GOT ONE FOR SALE?????
Re: r154 box needed Sat, 18 January 2003 05:04 Go to previous messageGo to next message
Er dude, they're both alloy case gearboxes. The only thing that's steel is the sandwich plate.
ROBBO_ma61
Re: r154 box needed Sat, 18 January 2003 05:39 Go to previous messageGo to next message
so where abouts on the box in that pic is the r154 too wide for the mk2 tunnel?
ROBBO_ma61
Re: r154 box needed Sat, 25 January 2003 01:43 Go to previous message
anybody found one or anybody got one for sale yet?
Previous Topic:AE86 fuel pump?? other external pumps??
Next Topic:URGENT SOARER WINDOW NEEDED
Current Time: Thu Nov 19 07:00:08 UTC 2026
Total time taken to generate the page: 0.013499975204468 seconds
